Question about Philips CDR760 CD Player
Getting opc fail message
Goes thru normal start up but then gives opc fail message
    Problem Solver:
  • 9 Answers
Hi, please read this link: http://www.fixya.com/support/t8055461-philips
if you have been using your old media and this happened with new media the problem is the record speed of new disk. if you are using the same old media maybe your recorder needs an OPU cleaning.
Posted on Mar 18, 2014
I just install a new opc belt in a xante colourlaser 1200 printer, it still say install opc belt.
You probably need to go into the menu structure and find the resets menu. It could be under machine info or maintenance. When you have found the reset menu or parts life, you should be able to reset the OPC Belt.
Jan 11, 2015 | Xante Office Equipment & Supplies
I have a Phillps 870 CD rcorder. Have been using TDK Music CD-RW, 4x, 700mb discs. Just bought new discs from same manufacturer and sames epcs but get OPC FAILED message
Welcome to Fixya.
OPC stands for Optimum Power Calibration. basically, it's a small test to write on the media and read it back for self calibration of the laser power.
I'd try different blank discs to see if it's sensitive to some. Of course they recommend only Philips brand but most major brands should work. Sometimes the "times x" recording rating needs to be higher or lower.
You can also try to turn unit on at least 30 minutes or more before use (this seems to work best for me)
The bottom line is that certain media and certain writers just don't get along, so there are no permanent "Fix" for this issue as every CD recording device encounters such once in a while.
Here's an excerpt from one of the tech members who experienced this problem :
"If I have an OPC Fail message, I try another blank. If
I find that they consistently fail (about half a buck wasted) I move
the stack over to the computer (which seems to work fine with these)
and buy another stack of blanks of a different brand next time I see a
good price..."
Hope this helps, Thanks for using Fixya.
Jul 09, 2011 | Audio Players & Recorders
I have a philips audio recorder cdr 760 When i try to record cd rw a blank audio tdk cd the machine said OPC FAIL What I have to do to record the cd rw on my Philips cdr 760 Thanks for your...
There are a lot of forums which discuss OPC failure and it strikes every hardware maker and brand of media.
The bottom line is that certain media and certain writers just don't get along.
The manual:
http://www.p4c.philips.com/files/c/cdr760_17/cdr760_17_dfu_aen.pdf
Discussion online:
http://homerecording.com/bbs/general-discussions/recording-techniques/phillips-cdr870-187247/
http://answers.google.com/answers/threadview/id/318687.html
"I don't buy expensive blanks. I buy modest quality blanks and watch
for sales so that I can them for about a dime a piece after the rebate
check comes in. If I have an OPC Fail message, I try another blank. If
good price..."
an interesting workaround:
http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000
"CDRW 5000 work around for OPC FAIL
Here's a work around for OPC FAIL on cdrw 5000 -
method 1: turn unit on at least 30 minutes or more before use (this seems to work best for me)
method 2: run OPC on an old cd that always works - after OPC passes, remove old cd and insert new CD (you only get 99 OPC runs per disc)
-or use a combination of the two methods
I've always used TDK and I recently bought a new batch and they stopped working. The old ones still work everytime. I don't know enough about the system to guess what the difference is.
side note: CDRW 2000 will finalise discs from the cdrw 5000 but not the other way around.
Hope that helps "
Jan 30, 2011 | Philips CDR760 CD Player
I have a MFC-9420 CN that is giving me an "unable to print message" after I cleared a paper jam. I have turned it off and on several times, as that is the only help the user guide gives. I've read...
To reset on this machine you press the 3 and 9 together and scroll thru the options to reset. Unable to print without an error code doesn't tell me where your error might be.
Jan 28, 2010 | Brother MFC-9420CN All-In-One Laser...
Problems sending. the paper starts to go thru then stops and prints out an error message
Try turning the machine off and on again.. it sounds like a memory problem..
If that fails give the fax a good blow in where the paper goes in.
Oct 16, 2009 | Brother IntelliFAX 4100 Laser Fax
OPC belt has 78% left -cant rid the problem
Look at the OPC belt edges, there's a shiny spot that passes thru a sensor, a can of air should blow out the sensor, carefully! When the sensor can't see the timing spot you get that error. You may have to replace the OPC since companies are imbedding a chip that tells the machine when they're used up.
Sep 01, 2009 | Brother MFC-9420CN All-In-One Laser...
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC9420 Unable to Print
i had this error, it ended up being the opc unit, it tends to drift and then the optical sensor does not line up, give this general error , we managed to get one replaced under warranty, but our second printer suffered the same, next your fuser will fail......
Jul 30, 2008 | Brother MFC-9420CN All-In-One Laser...
Open Questions:
Philips CDR760 CD Player Logo
250 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
