Question about Hilti Hammering
Hilti te805 what oil is used in the te805 and how much do you need
Hi, Any parts for Hilti Core Drill, What to service it. What oil/grease used in gear box. Thanks. Peter Scott N Wales. LL41 3HLo
I think standart filled with its the expensive Turmopol oil but there are also much cheaper lubrications also by Hilti to get for this fabulous tool.
I think the
SAE 20-20 its fast the same like Turmopol hd20 the price is much higher of the original Hilti Turmopol maybe by special dopes in the oil.
If its leaking water in front of the bearing replace always all oilseals and gaskets in the front of the tool much more is most case not neccesary.
Apr 11, 2016 | Hilti Drills
I have a te 500 it not knocking at full strength
A Broken front ring which blocks the lock bolt ?
Is there enough lubrication flow if something is broken inside replace ALLWAYS a complete servicekit , because its , beware of the Turmopol oil is expensive. there are equivalent oils if you asked special for it also by Hilti to buy.
Hilti and Duss are not the 2 cheapest brands of powertools.
Special Tolerance-free bearings are used it is all super calculated on a number of operating hours and about if something is defective, a complete overhaul is necessary.
These hammers may leak no trace of oil in the front until 2006 HILTI has in my Country support , but after this date
exclusively support to the end-users and support closed for brokering.
Feb 15, 2014 | Hilti 120-Volt SDS Max Demolition Hammer...
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
The drill is leaking oil
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Nov 11, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Te76 will run but will not hammer
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Aug 13, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hi.I am trying to find a triger switch for a Hilti TE72 The switch fitted is a ''MARQUARDT 1264 1601 but any alternative would sufice. Thanks Keith
this is quite an old machine and the switch will no longer be abailable from hilti. However the TE805 has a very similar switch. instead of a trigger switch its a rocker switch, but it is possible to unscrew the top off your old switch and attach it to the new one. the part number is 17904
Mar 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
What type of oil is used in the Hilti hammer drill casing?
what oil do I use in a te80 hammer drill
Oct 26, 2009 | Hilti Drills
Hammering Logo
137 people viewed this question
Top Hilti Hammering Experts
Todd Arndt
Todd Arndt
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hilti Hammering Expert? Answer questions, earn points and help others
