Question about Hilti Hammering
Hilti 805 what oil is used and how much
3 Suggested Answers
  • 123 Answers
SOURCE: i nide a chuck for a hilti model te 805 chiping
That chuck is not just one piece. If in the U S contact Hilti @ 1 800 879 8000
Posted on Jan 21, 2011
  • 3828 Answers
SOURCE: How do you grease a hilti te 805?
Hilti TE 805 Instructions Use Manual not helpful at all
no time to take the tool all apart ..must be some external way
can you make anything out on the hilti te 805 drawings
save images as a pdf then you can magnify easily
Posted on Jun 16, 2016
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Can anybody tell me the correct type and weight of oil a 2004 volvo xc 90 uses also # for replacment oil filter
Oil filter is provided by year,make, model of your vehicle at the parts store. ---
Oil and fluids Oil quality
Engine oil must meet the minimum ILSAC specification GF-2, including ACEA A1, API SJ, SJ/CF and SJ/Energy Conserving.
Your Volvo has been certified to standards using ILSAC oil specification GF-2 5W-30. Volvo recommends use of oil with a quality rating equal to or higher than ILSAC GF-2. Equivalent and better oils include ACEA A1, API SJ, SJ/CF, and SJ/Energy conserving. Lower quality oils may not offer the same fuel economy, engine performance, or engine protection.
Volvo Cars recommends Castrol. Depending on your driving habits, premium or synthetic oils may provide superior fuel economy and engine protection. Consult your Volvo retailer for recommendations on premium or synthetic oils. Oil additives must not be used. NOTE: Synthetic oil is not used when the oil is changed at the normal maintenance is carried out. This oil is only used at customer request, at additional charge. Please consult your Volvo retailer. Operation in hot climates.
When temperatures exceed 86° F (30° C) in your area, Volvo recommends, for the protection of your engine, that you use a heavier weight oil, such as SAE 10W-30. See the viscosity chart below. pg129a.jpg Oil viscosity (stable ambient temperatures)
Operation in temperate climates
Incorrect viscosity oil can shorten engine life. Under normal use when temperatures do not exceed 86° F (30° C), SAE 5W-30 will provide good fuel economy and engine protection. See the viscosity chart above. Extreme engine operation
Synthetic oils meeting SAE 10W-30 and complying with oil quality requirements are recommended for driving in areas of sustained temperature extremes (hot or cold), when towing a trailer over long distances, and for prolonged driving in mountainous areas. Changing oil and oil filter
Oil and oil filter changes should be made at 7,500 mile (12,000 km) intervals. Volvo does not recommend the use of oil additives.
Synthetic oil is not used when the oil is changed at the normal maintenance intervals except at ower request and at additional charge. Please consult your Volvo retailer.
Aug 05, 2010 | 2004 Volvo XC90
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What type of oil do I use for the blade?
Don't use car oil or anything else,but the recommended purpose lube,which you can pick up
at any home improvement store. The oil has a special
viscocity,which will work properly in the chainsaw.
Apr 01, 2010 | Remington Electric Chain Saw
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
  • Colder use SAE 10 oil.
  • Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
  • It is normal for oil to seep when saw is not in use.
  • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Polesaw Wizard
What type of oil do I use for pole saw?
Use bar and chain oil (bar oil is SAE 30 with an addative to make stick to the bar and chain) available at home centers and hardwares. Excerpt from a Remington OM follows:
“FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil.
Note: For temperatures below 30°F, use SAE #10 oil.
For temperatures above 75°F, use SAE #40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.”
Lou
Mar 09, 2010 | Remington Polesaw Wizard
What type of engine oil does a kx80 1995 take
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil. Brand of oil doesn't matter.
Use 10w40 motor oil in the gear box. Don't use any synthetic oils, oil marked "EC", or oil with "special" additives. Stick with the major brands; Pennzoil, Quaker State, Mobil or Shell. If in a hot area like Texas or New Mexico go with 20w50.
Aug 02, 2009 | 2006 kawasaki KX 450 F
I need to know what weight oil to use in my 03 kawasaki kx 125
A “very helpful” rating for this answer? Thanks!
Jun 30, 2009 | 2003 kawasaki KX 125
What oil in crankcase of dt175 about 88 model
Jun 14, 2009 | 1974 Yamaha DT 360
What kind of gear oil for 2003 rm 85
Please top rate this answer. Thanks!
Jun 07, 2009 | 2003 Suzuki RM 125
Hammering Logo
253 people viewed this question
Top Hilti Hammering Experts
Todd Arndt
Todd Arndt
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hilti Hammering Expert? Answer questions, earn points and help others
