Question about Kenwood KVT-617DVD Car DVD Player
Wiring diagram Where do you plug usb or MP3.just can't find out where it would go
How do I download music from my computer to my mp3 player
If the mp3 player has a USB wire, plug that into the usb plug on your computer, then on your computer (if it is windows) go to START, and go to MY COMPUTER, and left click (double click?) this, to get a picture of your drives such as C:
One of the drives will be the internal storage of your mp3 player, and you can click to go into subfolders.
Just copy the mp3 file into one of the folders of y our mp3 player as if you were adding it to a hard drive or a usb drive.
Sep 01, 2014 | Eclipse Audio Players & Recorders
JVC KW-AV71BT wiring diagram
My ipod jack used to work, I unplugged ipod then plugged it back in. Now it shows on the screen that the ipod is connected and playing, but now sound comes out. This is only on ipod, everything else works fine
Feb 02, 2014 | JVC KW-AV71BT In-Dash DVD/MP3/USB 7"...
Coby touch screen mp3 won't plug into anything
I use one of my other usb cords for my amazon and it works fine
Sep 23, 2012 | Coby MP828 MP3 Player
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
Lost charger for samsung yp-k3 2gb mp3
The MP3 player is charged by connecting the supplied USB cable to the MP3 player and then plugging the other end of the USB cable into the USB port of a working computer.
You can also purchase a 5 volt mains USB adapter. Connect the MP3 player and USB cable to this 5 volt mains USB adapter to charge the MP3 player.
Dec 28, 2011 | Audio Players & Recorders
Where do you plug in the mp3 player to transfer music?
You MP3 player will be supplied with USB cable. Attach the cable to the MP3 player and plug the other end of the cable into a computer's USB port.
The computer will see this as an removable device, you can then open this device and copy mp3 music files from your computer and paste these files into your MP3 player.
Nov 07, 2010 | Compaq Presario 5000 PC Desktop
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | Audio Players & Recorders
Kenwood KVT-617DVD Car DVD Player Logo
37 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
