Question about Samsung Office Equipment & Supplies
Transfere belt error
Samsungclx3175fn display says tranfer belt error
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 150 Answers
TRANSFER BELT CHIP COUNT IS END REPLACE TRANSFER BELT
Posted on May 08, 2014
2 Suggested Answers
SOURCE: Transfer belt error
I called Samsung because my printer did the same thing. Try a hard reset, if that doesn't work you have to replace the transfer belt. hit Menu then # then 193 Black Start....you have to do this all in about 3 seconds. It will come up and say Select Country (USA) hit OK and then it is suppose to reset it. If it doesn't work the transfer belt has to be replaced. If you are under warranty they will send you this for FREE.....
I am out of warranty and have to pay $150 to get one.
Good Luck
Posted on Oct 31, 2008
C-0096 whats that mean .. how can i clean it .
Image Transfer Belt pressure/retraction error.
If it is the image tranfer belt error, take it out and inspect it and make sure no clips, springs and stuff have not come off or loosened.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 27, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
"981 Service Switch Error"
981 service switch error refers to BUD(belt up/down) clutch if the error essage is hard. it could be possible that someone could have playes with white CAM below the tranfer belt(behind the waste toner box) if you suspect that the cam was manually rotated, then you are in a big FIX. if not then it could be just a problem with the cam being worn out. in this scenario you cannot remove or reset the transfer belt as you normally do it. there is a special procedure to remove the transfer belt. try the following.
remove the waste toner box., fool the front door of the printer so that you can watch the transfer belt moving up/down. while you have the fron door open,
Turn off the printer, press and hold the go and return buttons on the printer , keep watching the shaft that show the position of the belt, once it moves, be fast enough to turn off the printer. If you were successful in this procedure , you can remove the belt from the printer without any problem. Make sure not to touch the white cam shaft. visually examine the internal mechanism of the shaft, if it is wornout replace it.
IF the white cam was turned manually then you might have to replace the BUD clutch.. which is the most difficult process in this machine....Wish you all the best.
Nov 12, 2010 | Lexmark C912 Led Printer
The screen reads "Transfer Belt Error"
Remove transfer belt from printer. Remove the tow screws and open the black shiney plastic plate on the side with the BLUE POST STICKING OUT. Remove the Two screws and the black shiney plate from the side with the GREEN post. On the green side there is a chrome silver metal strip overhanging the cover bar. remove it by lifting it in a sliding manner toward the crossbar that straddles the belt across the bottom of the transfer assembly. Remove the four screws and remove the crossbar. Spin the belt forward or backward untill you see a tiny window inside the edge of the tranfer belt itself Clean both sides of the window with a q-tip with a light alcohol. also, there is an optical gap device on the bottom of the blue side. one screw will remove the entire assembly. there is powdered toner stuck in the optical gap on the receiver side. Blow it out anyway you can. high pressure works good. Dont use heat at all or the powder will magically turn into hard plastic and you will never be able to remove it. then re assemble the unit and make sure the little window aligns with the optical gap assembly that is hiding under the crossbar. Problem solved.
Oct 06, 2010 | Office Equipment & Supplies
Error 0x80070052 displayed in nokia e71 system
MY FRIEND THERE IZ VIRUS IN UR PHONE. PLZ CONTACT A GOOD SHOPKEEPER AROUND U.
Mar 25, 2009 | Nokia E71 Smartphone
Not sure which part that may need to be replace
tranfer belt is a large mylar black belt.
transfer roller is a skinny gray foam roller
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Error 0070
I don't see this error in the book. Are you sure of the model CLC-1120 )?
Jan 29, 2008 | Canon CLC 1120 Color Copier
Transfer belt error
Good Luck
Aug 13, 2007 | Samsung CLX 3160fn All-In-One Printer
56 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
