Samsung synchmaster 913n vga connected to pc and monitor but black screen just, if i press the leftest button it says "test good" but still black screen
I bought a samsung sunchmaster 1 day ago but when i plugged the vga cable in the pc and monitor, i get a black screen even if i set the options to extend. when i press the menu button it says: "test good" after that it keep being black, checked the capacitors and i dont see anything wrong, even the big 1. no pins are bended either at the vga cable. been searching for hours
    Problem Solver:
  • 12 Answers
I would first check to make sure your video card is seated properly, unless you have an integrated video chip then you might want to insert a video card on the PCI slot to make sure that the problem is not with your motherboard or your PCI slot. If no problem with that, use a flash light at an angle to light up your monitor when your computer is on and plugged into your monitor to see if the screen is on but maybe too dim too see. If that is the case it sounds like the capacitors in your monitor might be causing a problem. Sometimes the capacitors do no look busted or bulged at the top, one might be bad internally without giving an indication by looks.
Posted on Mar 18, 2014
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: HP L1706 LCD Monitor - 'No Signal' Problem
Try to replace your memory.
Posted on Feb 24, 2009
michael_grey
  • 365 Answers
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Posted on Jul 21, 2009
  • 164 Answers
SOURCE: Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Posted on Jul 24, 2009
  • 1684 Answers
SOURCE: Samsung 244T 24" LCD Monitor suddenly lost
The problem you are having is a common symptom of a failure in the power supply. Parts called capacitors start failing. When they fail they stop filtering the voltages correctly and the power supply shuts down to prevent additional damage. If you would like more information on capacitor failure please check out this page on our web site explaining what they are and what they do: http://www.ccl-la.com/blog/index.php/capacitors/ If you can solder then you can do the repair yourself. We have a kit available with all the capacitors that you need to replace. The kit details can be found at: http://www.ccl-la.com/catalog/product_info.php?products_id=124 The kit contains all of the capacitors that need to be changed on the board to return it to full operation again. If you don't want to do the repair yourself we do offer a repair service for this unit. You can get details on our repair service at: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
BuddyMc
Corporate Computer
www.ccl-la.com
Posted on Nov 25, 2010
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I have a blank screen. Only when I press menu do ...
Me too... If I put it on 640x480 it also complaines that it want 1280x1040@60hz but there is newer a picture eaven if I give it that resolution...
May 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Floating box telling me to adjust to recommended screen resolution which is correct, can't get rid of floating box on a blank screen
restart the computer immediatly press f 8 and press frequently f 8 untill menu appears then highlight on "enable vga mode" and press enter your problem will be solved
Mar 30, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Syncmaster 913v not optimum mode
I just resolved this problem for my SyncMaster 913N.
It seems to be a known issue, however it can take quite some time for the problem to occur. In my case about 3,5 years, so well out of warranty.
Short term solution: unplug your monitor from power. The switch on the front is not good enough. Pull the plug and leave it for an hour or so (all night if you can). Good chance the monitor will work next time you power it up.
The problem will is likely to come back..
Permant fix requires some basic soldering as per this video:
I just managed it and it has been ages since I soldered a resistor so you may very well be able to do it. I spent $25 on tool and part and saved me from buying a new monitor.
Mar 20, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
When i start up my computer, the screen is all black even tho the monitor is powered. Then when i press menu, it says test good, and goes back to black screen?:s
There are two kinds of inputs your monitor can take. I believe you are currently using the VGA input. Try DVI and see if it resolves the problem.
Sai.
Mar 04, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Just bought new tower pc,when connecting to monitor getting error box which says"not optimum mode,reccomended mode 1280 x 1024 60hz ? any thoughts?
hi,
I think the operating system your using has less color drives or on board VGA has less color dives which would work with the monitor .
An upgrade of your operating system would fix it .or buy a VGA card and this will come wit its color drive installation CD ie
Good luck
Jan 16, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
Samsung SyncMaster 913N screen not working
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Worst case will be the lamps.
Nov 14, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
HOW DO I HOOK MY SAMSUNG SYNCHMASTER TO MY COMPUTER? I HAVE THE DVI CABLE CONNECTED TO BOTH AND IT KEEPS SAYING CHECK SIGNAL?
Prior to attaching the SynchMaster and if there is another monitor, pls try lowering the Screen Resolution of your Display Properties. It may also be necessary to lower down the Screen Refresh Rates. In some video card, you may have to activate Twin/Extended view or enable the use of a second monitor assuming that your regular monitor is connected to the standard 15pin VGA and that the Samsung would be the 2nd monitor using the DVI.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
