Question about Garden
Runs away i cant control the cultivator it runs away
  • 1,162 Answers
What do you mean? Does it not throttle an runs wild? Or does it take off in the ground?
Posted on Mar 26, 2014
Troy bilt pony,moves so fastu cant hold it back,??????
I found that when you have the tiller at full throttle it can get away easily. Try pulling back the speed a bit and change the depth of the tines to grab a bit more but not enough to launch it. Good luck! Hope this helps you. Cheers, Michele
Oct 20, 2014 | Troy-Bilt Pony Garden Tiller
Mantis tiller qiuts after a short running time ,then cant pull the recoil rope
Anon, it sounds like you need to get your Mantis serviced. If you cant pull the recoil rope it sounds like the coil is overheating and obstructing the fly wheel.
Jul 11, 2014 | Mantis 2-Cycle Tiller
I just bought a returned Ryobi GC430 at a reduced price at Home Depot. I took it home and topped off the oil, which was a little low, and put fresh gas in it. I finally got it running but the tines will...
Ryobi engines have a plasic camshft that when it get hot melts the lob off the exshast end and the engine wont run if it cant exshast remove the valve cover and you will see for yourself
Atlantis Small Engines
Aug 17, 2010 | Ryobi Cultivator
New tines now gets away from me
double check to make sure you have the new tines in the right direction. also you could try to raise your machine, as the new tines are digging better it might not have to be as low as you had to go with your old ones.
Mar 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
My rototiller runs but then stops like it is out of gas what can i do to fix this
How long does it run? If its only a few seconds this sounds like a dirty carb. If it runs longer, does it restart right away or not? Sorry can't tell you much more without more info. Good luck!
Mar 14, 2010 | Garden
Troy built cultivator will only idle 26cc 5yrs old
Problably not sucking air, but not getting enough air. Does your cultivator use gas/oil mix or straight gas? If it is a gas/oil mix the muffler is probably stopped up with carbon and cutting off the air flow. Try removing the muffler and see if it runs better.
Jun 11, 2009 | Troy Bilt Tiller/Edger 26cc, Model No....
Tiller won't stay running
If you choke or prime the engine, it starts up for a second or two and dies, the carburetor need to be cleaned/repaired.
May 25, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
