Question about Hitachi 32" LE32T05A Full HD LED- LCD MultisystemTV FOR 110-220 VOLTS
SCREEN IS DEAD BUT POWER LIGHT IS BLINKING BLUE
Led blue light blinking but screen is dead
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Check your backlight. It may have burnt out. Easy solution is to get a new tv.
Posted on Apr 12, 2014
Maybe your tv is asleep or snoozing. wake it up.
Mar 18, 2014 | Hitachi 32" LE32T05A Full HD LED- LCD...
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
My screen went black and blue power light is blinking
The tv power supply board is dead.That the board where the power a/c cord plug into it.Tries websites llike Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 02, 2010 | Hitachi P50H401 50 in. Plasma HDTV
The red light in the bottom left corner keeps blinking and it wont turn on. Yet when i unplug the tv and plug it back in the blue light comes on but then turns into red light blinking again and it wont...
Ur tv power supply board have dead componnents call capacitors.These capacitors are leaking gas,and it bulges up on it top or puff up on it top.These capacitors parts are dead,they must be replaced.U know basic electronic's and soldering?Take ur tv aparts,the board where the power cord plug into it.That ur power supply board,searches all around for these dead gas leakage capacitors,replaced them.Ur tv power LED light will be stable and the tv power will work again.Or tries websites like Shopjimmy.com,ebay.com to buy a whole reburbish power supply board for the replacement.
May 24, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
I've got an F755US that is not turning on. There is a blue light blinking on the right side where the ac power plugs in. I've searched the 'Net and have tried a number of the options regarding powering...
you forgot to say the SCREEN IS DEAD and BLACK on no text ever shows up there, nor do BIOS screens work (even with HDD removed)
mine has 3billion transistors , any of which bad can kill it dead.
we dont guess we do tests.
called diagnostic testing, or go broke guessing. see?
leave the battery out for now, batteries can and do short often.
next is the power pack 19vdc, good, 10v bad we test that using a magic tool called a voltmeter ($20 in stores, DMM)
i have 100 solutions (i pass) or just 3.
1: bad power pack; battery out.
2: bad mobo (we can tests here all day ,wana? asK)
3 : dead screen, does the external jack vga work to external monitors?
is this a PC 2008 with the horrid solder ball problems.????
gee the service guide on line is time stamped, 2007
i call solder balls.
http://pcdied.com/black-screen.html#solderball_hell
Guess 2, the CCFL is dead.
but the external VGA works. !
in the link above see all words on CCFL. (back light and the easy test there) see the flash light trick?>
Jul 20, 2017 | HP Compaq Presario F755US Laptop
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Hitachi 32" LE32T05A Full HD LED- LCD MultisystemTV FOR 110-220 VOLTS Logo
42 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
