Question about Medion Computers & Internet
Medion pc mt6 wifi switch? desktop no fn key
Wifi switched off? How to switch on. no fn key was working now will not connect
    Guru:
  • 94 Answers
Http://www.medion.com/gb/service/download/driver.php, go to this website, enter your msn number and download the software that will activate the hotspot keys to enable your wifi.
Posted on Apr 03, 2014
  • 4 Answers
SOURCE: Cannot enable wifi with Fn + F10, stopped working.
You will want to go to your network connections and disable and re-enable your wireless networked card. if this does not work reply back to this.
Posted on May 09, 2009
  • 212 Answers
SOURCE: How do I switch on my wireless switch on my Medion PC (desktop)
it is in your control panel under wireless.
Posted on May 24, 2009
  • 32 Answers
SOURCE: Medion formatted, need network drivers
go here, input ur computer serial and download drivers
http://www.medionusa.com/
Posted on Dec 30, 2009
Cool Sam
  • 79 Answers
SOURCE: Award BIOS W 6701M7 v2.12 update if available
you will get the BIOS update from HP.com
www.hp.com and then go to Support and Drivers and then put the model no. of the comp
Posted on Mar 19, 2010
UpGrade
  • 113 Answers
SOURCE: wireless wifi to my presario f700 pc not working,
Here is the problem, the Nvidia Chipset needs to be reflowed. Now if you have the right tools this an easy job, simply look up the reflow temp range and do it. I used a hot air SMD rig wrapped the board in aluminum foil several times, cut out the hole for the Chipset and slowly heated it up I used a digital thermometer and watched the temp range, at 300 F I turned it down and began to cool it. When completed I let it sit until cool. I pulled the thermal pad and replaced it with a penny. (I cleaned the penny, heatsink, and chipset, and lightly applied artic silver to both sides of the penny, and the onto the processor and put it all back together. When I booted the system recognized the wireless and has been working for about 6 hours now, I have moved it around held it under the case and all seems well. If its between the bin and trying it yourself, try it. a cheap heat gun can be had for as little as $9.
Posted on Mar 28, 2010
How to activate wifi on medion notebook
Check BIOS, you find Wireless settings.
May 29, 2014 | Medion md40298 Notebook
No fn key on external USB keyboard on MEDION S5612
Right click on the wifi icon on the taskbar by the time, then click Open Network and Sharing Center. On the left side of the window that pops up, click on "Change Adapter Settings". You should see your wireless adapter listed here, and can enable or disable it from here.
Jan 29, 2014 | Computers & Internet
How do i connect wifi to sylvania 7 netbook
Does it come with wifi built in? If so turn on the wifi. There might be a switch on either side or the front of the laptop. If there is no switch you can probably use a combination of keystrokes such as FN function key + F1 thru F12. Press and Hold the FN key then hit the corresponding F1 thru F12 key that controls the wifi. The correct key will have the wifi icon )))) on it. If you watch the LCD Screen when you hit the key to toggle the wireless it will display Wireless On or Wireless Off.
If your laptop does not have wifi built in you can purchase a USB wireless adapter that plugs into one of your USB ports for less than $30.
Try http://www.tigerdirect.com
Apr 03, 2012 | Computers & Internet
My wifi not working
LOL, wifi does not work off a network cable. The network cable is used for a local connection to a modem or router. Wifi doesn't not require a cable. Did it use to work? Have you checked on both sides of the laptop and in front of the laptop to make sure you have not turned the wifi switch off if there is one? Have you checked to make sure you have not hit the FN (Function Key) + (F1 thru F12 function key) that toggles the wifi on an off? When you Press the FN key and hold it down while pressing the Function Key that corresponds to toggling the wireless normally it will display on the screen Wireless On or Wireless Off. The correct key should have a wireless signal icon like )))) on it. That's the key you want to hit while holding the FN key.
Mar 18, 2012 | Computers & Internet
How to turn on WIFI?
Look at the sides of your laptop. Look for a sliding switch with a wifi wave icon. Manually slide it to turn the wifi radio ON or OFF.
If you don't have that mechanical switch, look at your laptop's Function Keys (F1 to F12). Look for a function key with a wifi wave icon printed in a different color. Example, if F10 has that wifi wave icon, hold down the FN Key and press F10 to turn your wifi ON and OFF.
Jun 11, 2010 | Acer TravelMate 2480-2779 Notebook
Where is the wireless switch on a Acer Aspire 5735
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
Nov 17, 2009 | Acer Aspire 5735 Notebook
No user manual with new little MSI netbook. Need to know how to enable wireless network. Is there a switch or key combination?
Try this:
FN+F11 turns wifi/bluetooth on/off
Look at the LEDs on the front, namely the left most two.
No Blue + No Green = All wireless modes off
No Blue + Green = Bluetooth Off, WiFi On
Blue + No Green = Bluetooth On, Wifi Off
Blue + Green = Both Bluetooth and WiFi on
Press Fn+F11 to switch between each mode in turn in the order above.
Configure your wifi access with whatever tool you prefer. Some use the built-in windows wireless network , others use the realtek one. Use whatever works for you. (personally, I use the windows one).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 28, 2008 | Computers & Internet
Computers & Internet Logo
135 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
