Question about Maytag MFD2562VEB Black 24.8 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star
Fridge not cooling. freezer is still working
Is the evap motor the most common problem with this model??
  • 4 Answers
This usually happens when your Defrost (heater) is not working, Firstly Get your Defrost Timer Checked. If that is the problem then the timer is much easier to be replaced. Depending on the models the Timer prices differ from $10 to $115.
If this is not the issue then Inside the freezer is the Defrost Heater Placed, and you will figure out that this unit is having the problem due to which the channels to pass the Cool air into the Fridge is blocked and not keeping it cool. You will have to check if this Heater can be fixed or replaced. *Again this cost will Differ based on the models*
Posted on Mar 18, 2014
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Warm fridge cold freezer
Mar 18, 2014 | Refrigerators
FRIGIDAIRE FRS6HR4HW2 FRIDGE IS SOMEWHAT COOL BUT FREEZER IS SAME TEMP AS FRIDGE I HAVE POWER TO THE EVAP FAN BUT FAN IS NOT WORKING COULD THIS CAUSE THE FREEZER NOT TO GET COLD ENOUGH TO FREEZE
Yes, if your evap is fully frosted, and the fan is not working. The frosted evap will keep it cold but since the fan cant move the cold air from the evap it'll be cold, but not as cold as you'd like.
http://parts.sears.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FRS6HR4HW2/1428/0165000/R0607119/00005?shdMod=FRS6HR4HW2
there is the screen you need to order a new fan motor. option number 13 is the fan motor. lmk if u need more help!
Aug 05, 2013 | Frigidaire FRS26H5AS Side by Side...
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
What should I check if the refrigerator is not cooling/working, but the freezer works fine?
first off what kind of frige and model number,the freezer feeds the fridge so no cold air is being blown into the fridge section from the freezer,open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor,put your hand on the back wall of the freezer,if there's ice or like snow on it you have a defrost problem,bad defrost thermostat,heater,timer or board depending on the machine,this is why i need the model number,also on some machines there is a damper that opens and closes to let the cold air into fridge section or the door was left open and the air vents are froze up,most common on bottom mount freezers,look at the freezer ceiling and packages,if you see frozen water droplets on the ceiling or packages it's a sure sign the door was left open.hope this helps.
May 03, 2011 | Refrigerators
Fridge side not cooling i have unplug for a minute and plugged back in starts fine and then i hear a click sounds like compressior is running but not getting cold
first off what is the brand name and model number?is the freezer cold?if so when you open the freezer door do you hear the fan blowing?all a fridge does is get cold in the freezer and the evap fan blows cold air from the freezer to the fridge side that's it,if you don't hear the fan when you open the freezer you have a bad evap fan motor,but send more info.
Apr 09, 2011 | Refrigerators
Fridge Motor
which one?evap fan motor or the condenser fan motor?i've seen the evap fan blades in the freezer wear out in the center where it slides onto the motor shaft so when the motor comes on the blade doesn't spin with it,need a new blade,or if the freezer is on top the drain blocks and the air vents freeze up,is there water leaking anywhere or ice on the freezer floor?need to send a little more info,also model number would help
Jan 23, 2010 | GE Refrigerators
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 02, 2009 | Refrigerators
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
Maytag MFD2562VEB Black 24.8 Cu Ft French-Door Refrigerator Bottom Freezer, Energy Star Logo
47 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
