Question about Hardware & Accessories
Hot water problems
Power is on but no hotwater is coming out of the taps.
  • 5,089 Answers
Can i connect hotpolnt aquatic to hot water feed thanks
Yes you could, but the machine is not built for it.
The other problem I see time to time is that the water valve gets stuck due to the heat. Its a cold water valve, not desiged for hot water. (internal gaskets and o-rings dont like heat).
And, your tap hotwater is about 65-80 degrees celsius. Do you want that for all your clothing? I dont think so
May 18, 2014 | Hotpoint Washing Machines
I have an instant hotwater system with the futher most bathroom about 45' away. I am looking at adding a recirculating pump on a timer at the furthermost bathroom to get hotwater quickly in the...
Maybe I am not understanding your problem exactly, but if you have the instant hotwater system installed it should be measuring the temperature of the water in the hot water line and if it drops below the set level it should open the hot water side until the temperature is reached. If it was installed correctly it puts the hot water back into the cold water line so it isn't wasted.
Sep 18, 2011 | Grundfos RCP-96 Recirculation Pump for...
Shower goes hot then after few minutes cold then hot again and constantly up and down. this shower is only 2 month old and has done this since fited
it is possible that the hot mix valve needs to be adjusted higher or there is a crossed plumbing line somewhere down the line. ( just wondering(?) are you tapped off a standard hotwater tank or a hotwater on demand system ? ). also, how is the hot water throughout the rest of the house ?
c...
Dec 29, 2010 | Home
Only get cold water entering washer ... no warm or hot
1. Close hot water valve behind washer.
2. Remove hot water line from washer side and place it in the drain.
3. Open hot water valve to ensure pressure and hotwater is ok in your drain.
4. If not, problem is home related.
5. If pressure and hotwater are ok, then see if your fill valve filter is clogged where you disconnected the hotwater hose attached to the machine.. Its called a fill valve. Sometimes they get clogged.
6. If the hot water side of fill valve looks ok with no blockage, then you might be looking at a new fill valve.
Feb 11, 2010 | Washing Machines
I turn the faucet and hear the water running, like maybe filling
depending on the distance of your faucet to the boiler, determines how long it will take to get the hot water.the water in the pipes cools when not being used, so this is normal
Aug 09, 2009 | Emerson InSinkErator C1300 Chrome...
Hardware & Accessories Logo
22 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
