Question about Whirlpool AWM8000 Front Load Washer
The letter f is flashing on my whirlpoolawm8000
Soon has it starts the whash it gos for 2minits and the letter f starts flashing
Please make a word from these jumbled letters: spoigs
6 Letter Word(s)
gossip
5 Letter Word(s)
pisos
4 Letter Word(s)
gips
pigs
piso
piss
pois
psis
sips
sops
3 Letter Word(s)
gip
gos
ops
pig
pis
poi
psi
sip
sis
sop
sos
2 Letter Word(s)
gi
go
is
oi
op
os
pi
si
so
Aug 10, 2014 | Games
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
The camera doenst start the ligth of empty battery is flashing the camera dont start
check for a blown fuse in the DC/DC board. Board is on top after you remove top cover, and the fuses are covered by a shield plate you have to unsolder. Fuses are very small and have letter codes like P or K
Mar 30, 2013 | Canon EOS 60D Digital Camera
Hello i turn my xbox 360 on and then start to play a game 2minits later it gos off and 2redlights flash
2 red lights is overheating. Please make sure your xbox is placed in a open area on a hard surface with the vents clear of anything for a better airflow.
Feb 25, 2011 | Microsoft Xbox 360 Console
Put chargar after 2minits notcharge
Please check your charger for malfunction. Check the voltage output of your charger. A good charger will has voltage out a bit higher than your battery voltage rate ( see voltage rate on nokia battery). The common problem for this case is the charger and is not the phone.
Regards
Jan 16, 2011 | Nokia E63 Cell Phone
1999 Nissan Maxama air bag light keeps flashing 11
Have it checked by a professional as soon as possible, airbag has a problem wich can be as simple as a short in the wiring or as harmful as the possibility of deploying airbags without any warning. Please take advice.
Dec 26, 2009 | 1999 Nissan Maxima
Nissan Maxima 1998, airbag lamp flashes
Check the air bag sensor. It probably needs replacement
Jul 29, 2009 | 1998 Nissan Maxima
Please I need the colors and in which number I need to put them back at the timer
If you look on the back of the timer,...if it is an older type timer/dryer which it sounds like it is because most modern timers have plug in type wirering harnesses,...you will see,(you might need magnifying glass), that each point to connect a wire at will have a y, (yellow), g, (green), blu, (for blue), R, (Red), V, (violet) and blk or bk for black and so on and so for stamped on the time next to the spade the wire connects to...write back with a model number if that doesn't help...
May 12, 2009 | GE Washing Machines
Whirlpool AWM8000 Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
