Question about Garden
Marcher motor running, hose connected and on , nothing happening
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
More info plz
Posted on Apr 21, 2014
When i push the start button, nothing happens. The motor has power, but does not switch on.
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Mar 03, 2014 | Jacuzzi Fuzion Whirlpool
Mirolin jaccuzzi tubs
Air Switch Repair
US Parts Center
Jan 28, 2014 | Home
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
Dryer quit in the middle of a load, pushed start button, hear an electrical buzz by the selector knob, nothing happens. tried another selection, nothing happened. checked lint hose & it was clear. is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 24, 2011 | Frigidaire FDE336RE Dryer
I have a jacuzzi vista 6 bathtub that all the lites come on and i here a faint noise but nothing else happens
there is an air hose that runs from the push button to the motor, it could have come loose, hopefully you have an access panel to look at the motor..
Jan 26, 2011 | Jacuzzi Home
The washer will start but will eventually have an "F1" error. This usually happens when water is running into the washer.
This is a problem associated with the machine/motor control assembly and/or the pressure sensor system. Either the machine/motor control assembly is at fault or it is sensing an error in the signal from the air pressure sensor circuit. Unplug the machine for half an hour or so to forcibly reset the machine/motor control assembly and eliminate the possibility of a simple electronic glitch.
Remove the three screws from the rear of the console assembly, if unplugging the machine does not resolve the issue, then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose (part number 353244) if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly (part number W10189966) if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses. NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer doesn't drain it just lights up on the drain cycle but nothing happens . wash cycle is fine.
need to open washer and check the DRAIN MOTOR PUMP it could be clogged , usually located at bottom side , small motor wit propeller where the DRAIN HOSE is connected , hope it helps , AJ
Nov 11, 2009 | Computers & Internet
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
