Question about Pride Health & Beauty
Wigwag has fell off how do you re connect it
How do you reconnect the wigwag
Hi. My Rascal Pioneer scooter won't stop beeping. It current in front of me top off and I've disconnected and reconnected all the connectors and nothing. It's not a free wheel alarm, checked that.
hi, is it a continuous beep or is there some kind of sequence a pause then a another series of beeps ?
Normally this means a critical error , someone is not contacted from brake to wigwag to motor, c heck for bad connections
Regards
Rob
Dec 07, 2015 | Health & Beauty
Why does myfreerider westminster jerks to start?,
hi , it could be the brake failing , have you checked all connections ? check the brushes but take care doing this ...
Need further then please contact me ..
Regards
Rob.
www.facebook.com/gewizrepairs
May 21, 2014 | Health & Beauty
Why does my freerider westminster **** when wigwag is pulled?
Hi,firstly it could be a worn throttle pot , incorrect values being received by the controller..
Secondly , the brake could be sticking hence the delay then movement and that would affect you in both directions...
For the brake i suggest you spray some contact cleaner or WD40 but remember you're lubricating the brake so take care when testing as it may still move when you stop...
Regards
Rob
www.gewizrepairs.co.uk
May 21, 2014 | Universal Health & Beauty
Sundancer scooter flashing wigwag code
The wig-wag can be tested with an ohm or multimeter. The wigwag plug must be disconnected in the tiller console or at the split-frame connector. Speed dial must be turned up all the way. Measure the wigwag with the ohm meter from the outer most tabs. It should read 5,000 ohms +/- 5%. Then measure center tab to either outer tab. When in "neutral" position it should read 2,500 ohms +/- 10%. If the wigwag is in tolerance I would have the batteries and battery harnesses checked next. Each battery should be charged and tested by a battery shop. These should be 12volt 18-35amp hour batteries.
If the batteries test fine then you have a wiring issue where a loose or corroded wire is dropping voltage under load. Sometimes these types of "bad" connections will cause the wire/connector to become warm or even discolor the connector/wire.
Best regards.
Mar 05, 2014 | Pride Sundancer 3 Wheel Electric Scooter
Whirlpool washer wont spin, belt drive with wig wag bar, wont spin tub or pump water
This brings me back a few years i have not seen a belt drive Whirpool in like forever. Some of the things to check are;
A broken white wire at the wigwag..the oscillitaing action of the wigwag flexs the wire and over a period of time that wire could break
the wigwag itself ...use a multimeter set to measure ohms of resistiance,each coil on the wigwag should have appx. 840 ohms if the coils are good
a loose or streched belt...when pushing on it their should be no more than a 1/2 inch of movement in it(if much more the belt should be replaced)
bent plungers that link the wigwag to the bars on the transmission....both plungers should be straight
that the notches on the bars on the transmission are square and rounded at the corners
That is what i can think of right now. Good luck i hope ya can fix that and keep that nearly antique washer going.
GENE
Oct 12, 2011 | Washing Machines
I have a kenmore 110.82372110 70 series heavy duty plus washing machine that drains but will not spin. Belt is intact and spinning. 'Wigwag' is oscillating
Hello.
WOW you have a old washer its been a few years since i even heard "wigwag"
now then their are a few possiblities;
1) the belt is loose/streched..is their more than a 1/2inch play in it...if yes try adjusting it by loosing top bolt on motor bracket and tighten belt by using hammer and push motor bracket to the left
2) are the plungers on the wigwag straight..if they are bent the plungers need replacing
3) is a wire on the wigwag broken..after years of "oscillating" a wire will break..the side with the red and white wire is for the spin
4) the lever that is pulled by the red wire side of the wigwag hanging up..check spring on back part of transmission to be good and pulling down the plate it attaches to when wigwag has positioned that lever in spin position
5) finally..when the above mentioned lever is in spin position( lever moves toward the rear) is the pulley above and in the center of the transmission spinning free or is it turning...if it spins free when lever is set to spin it should not spin free but move the tub to spin
Here are the part numbers;
BELT...95405
WIGWAG w/the plungers...89814
SPIN TUBE...285897
Thanks for taking me down a trip on memeory lane..its been since 1987 that Whirlpool has made a washer with a belt all are direct drive and its been a few years (several) since i have worked on on as "vintage" as the one you have...but like riding a bicycle i have never forgot :)
GENE
Aug 30, 2011 | Kenmore Washing Machines
Drains but won't agitate and spin
Sounds to me like your WigWag switch is bad. I know name sounds funny, but it is the switch that makes it go back and forth (WigWag) and agitate. It is a small unit with two wires going to it. Usually about in the center if looking from under the machine.
Aug 16, 2009 | Roper RAS8244KQ Top Load Washer
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
New 208 dodge charger with factory wig wag lights sometimes work and sometimes don't
To activate factory wigwags in a 2007/2008 Police Dodge Charger, connect pin 1 of the 24way upfitter connector found at the console (near the radio) to battery voltage -- the 47k series resistor is only required for MY2006.
That connection causes the VSIM module (located under the AM/FM radio) to send a CAN message to the FrontControlModule, where the front control module drives the headlights in the wigwag mode.
Pin 2 of the upfitter connector does the rear wigwags.
Some of the pinout of the 2008 upfitter connector from the VSIM to the console is different than 2006/2007 -- a Chrysler harness booboo for 2008.
Note that the VSIM (also known as PTIM) module is only on factory police Chargers -- civilian cars do not have this module.
Jul 18, 2008 | Dodge Charger Cars & Trucks
Health & Beauty Logo
24 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
