Question about Pride Sundancer 3 Wheel Electric Scooter
How to remove the flip seat on a 1989 Searay DA220
The boat seat flips from facing forward to facing backward.
How do I remove the seat to remove the battery?
pull the lever and lift, or unlock the lock under front of seat and tilt back seat, or pull levers and tilt pull forward lift off, or flip lever in back and slide out, or undo front or back and slide out the batteries.
Make/Model PLEASE.
Nov 30, 2015 | Health & Beauty
I have a 1991 Volvo 740 wagon. I've tried to put the back seats down flat before, but i can never quite get it to go down all the way. Is it possible? If so, how? Thanks!
You have to flip the bottom of the rear seat forward. There should be a strap to pull where the seat bottom and seat back meet. The seats will not fold all the way down with out flipping the bottom up first.
Jan 31, 2015 | 1991 Volvo 740
How to fold down rear seat on Porsche Cayenne
Remove headrest, there is a small button on the base of the headrest mount you need to push in. Next pull up the strap at the front of the seat cushion bottom, then flip forward. Press in the flipper on the top of the seat back and pull forward.
Sep 06, 2014 | 2009 Porsche Cayenne
The front seat will not move forward but the electric motor does allow it to move backward. We were thinking that the relay is bad.
consistant_24.gifconsistant_25.gifconsistant_26.gifconsistant_27.gifconsistant_28.gifPlease don't forget to give ma a great review! The authentic service docs. are as good as I can do...
Mar 26, 2011 | 1999 Buick LeSabre
2nd row, passenger side seat will not slide forward after you tilt the seatback forward to allow for rear entry. Is there something that is locked or anything I should be looking at to fix this?
There is a little green plastic clip that is attached to the cable and pull lever, if you trace from the pull lever and cable to mechanical lever then to bottom of the frame it is on the bottom half of the seat, you will see it once you flip up the seat bottom over , on the black metal frame is where the clip is at, towards the bottom and facing the other seat frame that your not flipped up. well anyways the green clip is probably broken, or the cable came undo( which I doubt) the clip is a weak point in the seat mechanism , you wont be able to find it a retail automotive stores, dealer item only , that's if they even carry it anymore, or you might try a junk yard and look around for another excursion seat or a f250 or super duty and use that one. I've heard that you might be able to use the American door lock clips plastic hardware, they are suppose to look alike, but ford wont tell you that. The kit is at AutoBodyToolmart .com Part # 9914 for about $26.99 , that's what I heard. Good Luck !!!
Oct 27, 2010 | 2001 Ford Excursion
How to remove the seat
Bubba, Under the front of the seat is a latch that you must release there is a rubber block that must be rotated forward to be able to release the two little knobs that it is wedged between Rotate the knobs inward and lift the front of the seat. the seat will flip toward the rear of the chair and you now have access to the batteries. to remove the seat disconnect the joystick cable from the base and slide the seat forward after you have it tilte back and lift it off the base. Hope this helps you
Aug 26, 2010 | Jet 3 Ultra Power Chair
I need to remove the bottom part of the backseat of a volvo s40.
The seat bottoms flip forward, there should be pull straps at the back edge to pull them forward.
From there you can unbolt the hinges for the seat bottoms.
Sep 09, 2009 | 2001 Volvo S40
Seat wont go back only forward.
I would remove the seat, usually held down by four bolts and flip upside down and see if there is any noticeable issue on the track like something in the middle of it that would be preventing the full retraction of it.. There can also be a chance that the switch has gone bad from wear
Let me know what you find
Mar 25, 2009 | 1997 Chevrolet Camaro
Lid Switch for Washing Machine
pop trims from ends of control panel
remove screws from bottom of control panel under trims
slide control panel forward and up from the bottom, and flip over backwards on its hinges
undo brass clips under control panel, NOTE* how the clips are installed
unplug lid switch cable
lift cabinet slide forward and remove cabinet
turn cabinet upside down
lid switch is accessible
assemble in reverse order
Aug 29, 2008 | Washing Machines
Pride Sundancer 3 Wheel Electric Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
