Hi.. M using a djm 800. dont know what happened but the lights of master volume are not moving up.only 2 green lihgts are on. it is not even reaching the orange level. on increasing the sound from the normal level to right, the sound seems to be cranky?? please help ...
    Problem Solver:
  • 11 Answers
There is a master attenuation adjustment on the back labelled MASTER ATT. By turning this setting down you effectively lower the output volume from the XLR (3 pin connections) giving you the ability to run more level through the desk and see the metering.
Another way is to run your speakers or amp at a lower volume and turn the djm800 up which will give the same result.
Posted on Mar 20, 2014
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: pioneer djm 800. (dj mixer) when
apply some spray (lubricant contact cleaner)from radio shack-----to master gain volume and move it up and down many times.
Posted on Sep 23, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Posted on Dec 18, 2008
djproaudio
  • 515 Answers
SOURCE: New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
dj-tee-j
SOURCE: My pioneer DJM 600 lost master output the other
hi there i have a djm 500 but i have the same screw on the back its like an ATT for master output and if i turn it all the way down i have no sound but if i turn it up it gets alot louder lol
Posted on Jun 28, 2010
My pioneer DJM 600 lost master output the other day, it was playing and the master out just died. the lights were still lighting up but no sound came out. I was using the RCA outs not the xlr and haven't...
Jun 11, 2010 | Pioneer DJM-600 Silver Professional DJ...
DJM 400 Keep going into over on the channel and the master volume
To keep your levels down keep the TRIM don which is the gray knob. Also keep the hi, mid, and low knobs at the medium level. The control cables are for using the fader start function.
Jun 02, 2009 | Pioneer DJm 400 Professional DJ Mixer
How to connect my qqualizer to my djm pioneer 400 mixer
Use the stereo master outs from the DJM into the A and B Inputs of the EQ (you'll need 2 phono to Jack or 2 phono to XLR cables) then from the A and B Outputs of the EQ to the power amp/ speakers, etc (you'll need jack or XLR cables depending on what is powereing your speakers)
May 27, 2009 | Pioneer DJm 400 Professional DJ Mixer
Pioneer djm 800 will only play through 2 channels on mono??
try to clean your fader with contact cleaner and move it many times after cleaning -check your connection plugs(buy it from radio shack near you.
Apr 11, 2009 | Audio Players & Recorders
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Master channel problem
There is a master gain volume on the rear of the unit. Make sure this is not maxed out. Keep it between 1/2 to 3/4's of the ay up.
If this does not solve your problem, your going to have to give me more details. What do you mean when you say "moved off 0 peaks red on left"? Do you mean that when you lower the master volume, the left signal is still hot (red)?
- OPTiC
A DJ Pro Audio Co.
Nov 30, 2008 | Pioneer DJM-600 Silver Professional DJ...
New DJM 600 User
- OPTiC
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pioneer djm 800. (dj mixer) when turning the master gain volume it doesnt turn the volume up or down unless you put pressure onto it.
Sep 09, 2008 | Pioneer DJM-600 Silver Professional DJ...
66 people viewed this question
 Grubhead
Grubhead
