Question about Ibanez RGD Series - RGD321 Electric Guitar - Black Flat Finish - Free
Jack female connector type
Hi, A friend gives me an Ibanez RG 321, but female jack connector is missing. What reference or type of connector should I buy for replacement ? Thanks Regards, Arnaud
Switchcraft
your standard 1/4 in mono female jack.
Posted on Jun 17, 2014
  • Glenn
    Glenn Jul 25, 2014
    Go to Radio Shack and purchase a 1/4 jack
5 Suggested Answers
  • 5603 Answers
SOURCE: when i put a new jack in my s series ibanez. It
Check for poor soldering. Also the jack or pots MAY be physically turning and shorting to the black shielding paint that is conductive in the "WELL" with the pots and jack. If you find that a lead is shorting to the paint, put some insulating material OR tighten to prevent rotation that brings the lead into contact with the paint.
Posted on Jul 31, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: sound is breaking up
Try another cable. If the cable is not the issue start inspecting the guitar's wiring. A bad solder joint or broken wire can cause problems. But I suspect the cable. An easy test if you don't have another instrument cable to try, use a multimeter and test both the tip and sleeve of the cable. You should have continuity on the tips of each end. And the sleeve should have continuity on both ends.
Posted on Mar 08, 2010
  • 5603 Answers
SOURCE: I have purchased 2 Ibanez
The input cable MUST be a TS (unbalanced cable) to turn the unit on. The sleeve of the input cable is what connects the battery. If you use a TRS cable at the input it likely will not turn on. A TRS cable has a tip, ring AND sleeve like many 1/4 inch stereo cables.
Posted on Sep 15, 2011
rzepka159875
SOURCE: Hi, My Ibanez AEL 20
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? rzepa181@yahoo.com plx helpme
Posted on Nov 27, 2012
Year and model of my Ibanez electric guitar. S/N F338594 It is an RG series
Your guitar was made at the Fuji-gen Plant, Japan in 1993, Production Number: 38594. The serial number does not tell us what model it is.
Jan 02, 2017 | Ibanez Music
I have an ibanez tone blaster,the lights and all come on but no sound is made. Can anyone tell me what might be the problem?
Some hopefully easy fixes : Input jack could be the problem, or connection from the amp to the speaker. Does the speaker hum a bit with the volume up almost all of the way without anything plugged into the unit? If not, check the connection from speaker to amp.
If it does hum slightly when u crank the volume, check your input jack -- it might be jacked up (pardon the pun) and you can fix that easily by soldering in a new one.
Jun 11, 2016 | Ibanez Music
Acoustic electric model ATL10 TT. Where can I get a bit for output jack?
I'm unsure what you mean by "bit". Are you perhaps lookng for the retaining nut that screws onto the jack fron the outside to hold it onto the body? If so, they are available in a pack of various sizes from Radio Shack.
Dec 05, 2015 | Ibanez Music
Turning it on?
This guitars turn on when a 1/4 male jack is fully inserted at 1/4 female jack installed on the guitar, also check the guitar female connector for looseness, it should be attached firmly, let me know a bit more to help more...
Nov 03, 2013 | Ovation Applause Series AE148 Super...
Input jack
any input jack should work!
May 15, 2013 | Ibanez Tone Blaster TBX30R Guitar...
I have purchased 2 Ibanez TS8DX Tube screamers. Both are broken right out of the box. I plugged a cable into the out jack and into my amp. I then pluggen my guitar cable into the IN jack. Pushed the pedal,...
Sep 15, 2011 | Ibanez Ts9dx Turbo Tube Screamer Overdrive...
My acoustic electric guitar is giving intermittent sound any idea how to fix this problem
A common problem is a WORN jack that is caused by the user NOT looping the guitar cable through the strap or their belt loop. The rotation of the cable as it is played wears both the plug and the jack and causes noise and dropouts. Also verify that the battery connections are corrosion free. Also verify the problem is not with your amp.
Sep 09, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
I got a ibanez bass soundgear gio series, when i move the cable plug in to the plug hole of the bass just touching the plug head attached to the hole, makes some circuitbreaker sound like "toc"...
The jack on the guitars is a stereo type jack. The "ring" contact actually is connected to the battery and whenh the PLUG is inserted FULLY it coonects the ring contact of thee jack to the slkeeve contact of the jack which completes the circuit to turn on the battery. Hence while insertying the plug you will firsst get a snap as the tip of the plug ties to the ground of the guitar which is floating and picks up hum. Next the tip will touch the battery connection and get a snap. Finally when fully inserted both the battery is connected as well as the audio.
SOME guitars, especially those with tuners built inj will try tio fire up when the tip (audio) touches the battery cinnection. This may cycle and create the repetitive sound as it tries to start.
Feb 20, 2011 | Ibanez Gsr100 Electric Bass
When i put a new jack in my s series ibanez. It works for a bit and then fades out.
Jul 28, 2009 | Ibanez Music
Ibanez RGD Series - RGD321 Electric Guitar - Black Flat Finish - Free Logo
126 people viewed this question
Top Ibanez Music Experts
Wayne Tolonen
Ted Maxwell
Kyle Steven OHare
Kyle Steven OHare
Are you an Ibanez Music Expert? Answer questions, earn points and help others
