Question about Husqvarna Garden
Mz5424s nostart mower cut off when I leaned over and now will not crank.checked the 2fuses on left side they were good.
  • 391 Answers
Most have a switch in the seat, when you leaned over it activated the switch. The switch may be broken and needs to be replaced or the wires are unplugged or have a poor connection
Posted on Mar 20, 2014
Left side is scalping especially when turning
Stephen Bent/damage blade or spindle, check your deck for support link pin missing, damaged or rusted out brackets, blade spindle loose/mount damages or rusted out, missing deck support spring,wheel/roller if equipped, damaged blades, Recheck tire pressure and front steering axles for bent/damage, etc.
When measuring deck for level, measure at blade tips not the deck on a flat level surface. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Lawn Mower Quality of Cuts Problems and Solutions
How to Adjust the Deck Height on Husqvarna
Craftsman Riding Lawn Mower cutting uneven
cutting uneven chopping up ground Craftsman Riding Mower
Jun 06, 2016 | Husqvarna Garden
91 Geo tracker no feul to engine. Checked fuse. Feul pump rely is good but has no power to it.
Security light on? Turn the key on for ten minutes, off for thirty seconds. then try to start
Jan 31, 2015 | Geo Cars & Trucks
Trying to locate the voltage regulator on a Troy built 50in. Cut zero turn lawn mower
check battery with a load test, check fuses for burnt one , voltage reg should be bolted to side of engine kinda flat aluminum with fins maybe 3 wires on it, one has a fuse in it good luck
Mar 02, 2014 | Garden
My 21: self propelled yardworks lawnmower leaves a strip of grass about one thiird from the left hand side of the mower when i mulch with it. When I bag it works good.
I'd check your blade and see if it needs sharpening. The mulching mowers need to cut then vacuum the grass up and then cut it again. They must be properly sharpened for this process to work properly.
James
Aug 26, 2011 | Garden
Lean left bank mulitple miss fires
If you are lean on the left side that rules out a spark issue so you either have a injector cutting out or a vacuum leak on that side.
Nov 29, 2009 | 1997 GMC Sierra
Seat pressure switch cuts off engine when I lean to one side
I WOULD TELL YOU HOW BUT I CANT BUT YOU CAN TAPE IT DOWN AND TEN TAKE THE TAP OFF WHEN DONE
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Garden Logo
76 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
