Question about Konica Minolta Office Equipment & Supplies
How to clear maintenace call2
Maintenace call2 what is it
  • Konica Minolta Master
  • 6,696 Answers
Replace the drum and developer after clearing counters then once drum and developer installed run require F8
this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 14, 2016
Problem is maintenace call2
Anonymous: So is your device! Can't answer a technical question when I haven't any idea which printer, copier or multi-function device you're writing about.
Please don't expect detailed resolutions out of thin air! This is not just for Anonymous. I have read over 20 questions tonight that do not give us technicians any more detail than the error code. Several of the manufacture's use similar codes that may be fixed by other means. Please quit being so vague!
Apr 04, 2016 | Office Equipment & Supplies
How clear Maintenance m2 call service this konica 164
M2 means maintenace time you have to replace 1) developer 2) drum 3) cleaning blade 4) drum charge unit and reset the maintenance counter / calibrate the ATDC. After you than that READY TO COPY will appear ;-)
Oct 17, 2014 | Konica Minolta Office Equipment & Supplies
How to reset konica bizhab 164 m2
press menu quick setting << quick setting <> (service mode) go to service choise and go to maintenanc 0 ok press back IU LIFE STOP MODE press continues . press back go to clear data go to maintenac clear and supplies clear ok power off and on
May 31, 2014 | Konica Minolta Office Equipment & Supplies
I have the message mintenance call2 how to reset
reset the counters, replace the developer and the drum then run f8
Mar 05, 2014 | Konica Minolta Office Equipment & Supplies
How to clear maintenace call M2 in docujet 4021
go utlite--stop--00--stop--01--chear data--supplise--rest--rest
turn off/on
and it well work
sorry for bad eng
Aug 02, 2012 | Office Equipment & Supplies
Forgotpasscode,howdo i unlock my laptop?
you need to clear comos but my advice send it to maintenace center
best regards
Apr 21, 2011 | Acer Computers & Internet
Matainance call2 problem
maintenance call 2 is a warning that you have to replaced your consumables. the drum kit, developer. reset first m2 then calibrate thru f8. that's it, then problem solve.
Apr 05, 2010 | Konica Minolta DiALTA Di183F Copier
Which says maintenace required
The message indicates its time to clean/change the drum or other items inside the printer. You can purchase a maintenace kit online or take it in for service. You can also clear this message if you don't want to service your printer ... follow these steps: ***Keep in mind not doing the maintence may cause expensive issues down the road***
1. Shut the Printer off. (Use the shut off switch)
2. Hold down the Left Side of the ITEM and VALUE Buttons while powering the Printer back on.
3. Continue to hold Buttons until the Printer says “RESET MAINTENANCE COUNTER”, Then release the Buttons.
May 07, 2009 | HP LaserJet 5000n Printer
Brakes
no difference. Can't get any bubbles! Damned things are still spongey. Must be air in there somewhere unless I'm missing something besides another brain cell. Anyone got any cunning plans please?ou could try reverse bleeding!! Syringe and a length of clear tube fill syringe and tube with brake fluid crack open the bleed nipple, let a small amount of fluid out, then connect tube to nipple open the nipple a bit more and push the syringe. Should see fluid come up into fluid reservoir, dont let reservoir overflow This sovled a problem on a honda once , after I changed the brake hoses!!,,,
Nov 10, 2008 | 2000 Moto Guzzi V 10 Centauro
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
