Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Brew unit block
Upon start up SELFTEST, unit will display "BREW UNIT BLOCK"
espressodoc
  • 29 Answers
SOURCE: Brew Unit Blocked
If when you first turn it on and it does not go through the self test and then says brew unit blocked. You may have a wire loose on the board, (common) The motor that drives the unit may be bad. In either case you should have a professional look at it. Google saeco repair and have choose an authorized saeco repar center.
Posted on Sep 04, 2007
mirran
  • 515 Answers
SOURCE: brew unit
Make sure you have brewing unit in start positions, if you have a press on your brewing unit make sure to press it to you hear a tick, then you can fit it in the machine.
Posted on Jul 11, 2008
  • 14 Answers
SOURCE: Brew unit missing
Make sure the unit is seated properly, if any part flew off or out, it can be replaced at www.partsguru.com
Posted on Apr 22, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Titanium Brew Unit Blocked
Check the shower screen on the brew unit.
Posted on Aug 06, 2009
  • 80 Answers
SOURCE: cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Posted on Aug 30, 2009
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block).
Sep 14, 2014 | Saeco Magic Comfort Plus Espresso Machine
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Hi, My saeco royal cappuccino is displaying, brew unit block. It has been checked and all is clear. It was suggested that maybe it was the gearbox? Is this possible, if so do you have an exploded view of...
the saeco brew unit is the same as a Miele brew unit from a cva 615. check to see if there are any Miele service centers near you. The brew unit needs to be lubricated with food grade silicone grease every 30 days. if you dont do that, the plastic gears in the gearbox can and will strip. Try to find another brew unit and see if it works with a different one. If not, you may need to send it in to a repair center.
Nov 20, 2010 | Saeco Royal Cappuccino Espresso Machine
Getting Fault 73 for my CVA 4070 at start-up. Have removed the brew unit to ensure is clean and plastic piece -- shaped like a block "M" or block "W" - is in the "W" position. Have tried a manual on and...
I have had the same fault 73. Miele is coming out to replace the drive and the brew unit. SHould be a $700 repair. Thank God for warranties. I'll et you know the end result once repairs are complete.
Jan 09, 2010 | Miele CVA4070 Coffee Maker
Aug 04, 2009 | Saeco Incanto Classic Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Incano Sirius brew unit blocked
It is possible that the problem is in the CPU board, check the board, and the capacitor next to the pump.
Jun 04, 2009 | Saeco Incanto Sirius Fully Automatic...
Brew unit and waste unit in place, brew unit is blocked
For Brew Unit Block:
  • Turn Off
  • Hold small coffee & hot wate atthe same time
  • Turn on with light (numbers sill appear)
  • Hold medium coffee util arm returns to normal position
May 27, 2009 | Miele CVA615 Espresso Machine
Brewunit blocked
It sounds like the brew unit is stuck with the platform tipped forward. This will prevent the dreg drawer from being put in or out. Your problem could be the result of a few things. Some you can fix, some may take more work. You can get the brew unit out by following the steps outlined on a partsguru.com, Brew group removal.
Dec 18, 2008 | Saeco Magic Comfort Plus Espresso Machine
The brew unit cannot be removed
I had the same problem. I apparently turned it off mid-cycle. The upper-left portion of the brew group stopped higher than it should have. I had to force the brew group out, breaking a small plastic cover in the process. I don't think that part's too important. Then I observed the orientation of the gears and visualized what orientation they needed to be in to re-install the brew group. I pressed all the sensors to trick the machine into thinking the brew group was installed and started the brew process. I released the sensors once the gears were in the necessary orientation. I re-installed the brew group and was back in buisiness.
Feb 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
355 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
