Question about ASUS N Computers & Internet
N76 disassembly How do i reconnect he 3 ribbons next to the HDD ?
How to disassemble LG u8180
To disassemble your phone, please follow the steps below.
  • Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers (circled below) and unscrew the aerial.
  • Remove the 6 screws (circled below)
  • Next remove the 2 rubber stoppers & screws above the main screen (circled below)
  • Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet (as shown below)
  • Your phone should now look like the picture below. Unclip the ribbon (circled below)
  • After removing the ribbon cable (above), carefully lift the metal part indicated by the arrow above. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with what's below. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  • Your phone will now be in two parts. To open the top half of the phone and get to the screen, run your fingernail fingernail between where the two parts of the housing meet (as shown below)
  • Your phone should now be as pictured below. The circled areas indicate where you'll need to remove the speaker and ringer in order to solder them to the new screen. The screen can be lifted away from the phone easily at this point.
  • Remove the LCD and replace with new. Reverse the procedure for disassembly and it's finished.
Take care and good luck
Take note, the pictures are that of lg u8120, it has the same disassemble process as lg u8180
Oct 27, 2010 | Cell Phones
I have replaced my Toshiba 205 laptop's keyboard a few months ago and all was fine. Now some keys don't work while others work if you push for a few seconds. I reconnected the ribbon last night and...
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one
Sep 20, 2010 | Toshiba Satellite A205-S4607 Notebook PC
How do I replace (access) the Hard drive in a HP Omnibook XE3?
6ya, wakes this up from 6 years ago
but here is answer, see these 3 spots
1 is hdd, for sure.
just like lets make a deal, door #1,2,3
the bottom door 3, is battery ,
xe3-4s4zmhj3prccinjirhq2melp-2-0.jpg it may not, its PATA drive back in the dark ages of LT.
with a huge wide connector. Ribbon cable to match.
it has 90deg, connector to the MOBO,
ok thanks to Ebay, we can see all the parts
it has HDD PATA drive CADDY
as seen here.
my take whole case split to reach it.
the stap is to yank it fee of mobo after unbolting it. x4
caddy-4s4zmhj3prccinjirhq2melp-2-1.jpg end dark ages.
Aug 10, 2010 | HP OmniBook XE3 Notebook
The tip of my AC charger broke off on the contact post of my samsung sph-a620. A new charger cannot make contact for recharging purposes. I cannot see how to disassemble the phone to access that electrical...
To disassemble the phone, you need to get he appropriate screwdrivers and follow the processes below;
  1. Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers and unscrew the aerial.
  2. Remove the screws,
  3. Next remove the 2 rubber stoppers & screws above the main screen,
  4. Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet,
  5. Unclip the ribbon,
  6. After removing the ribbon cable, carefully lift the metal part. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with just the screen and the keypad rack.
  7. On the circuit board, you'll see the charging port and the broken charger that is in it.
  8. Try to pick it out with a pincher, and if you cannot, then you have to replace the charging port.
  9. Disconnect the charging port and replace it with a new one.
  10. Reverse the process to reassemble the phone back together.
  11. Take care.
Jun 22, 2010 | Samsung SPH-a620/VGA1000
My nokia N76 has only 2 hrs of battery time!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! wats da problem???????????
Hello Sir/Madam,
I think you buy a new battery. And charge only for 2 to 3 hours until complete. Then remember charge only when your battery is nearly to finish or left half battery.
Thanks. Good luck
May 20, 2010 | Nokia N76 Cellular Phone
MY HARD DISK HAS EXPERIENCED A PROBLEM I CANT INSTALL THE OPERATING SYSTEM. I GET AN ERROR SAYING DISK FAILURE AND ITS DOWN NOW I CANT DO ANYTHING
Disk failure = the hard disk has a hardware failure = it's dead. It can't be fixed, replace it and reinstall.
Apr 15, 2010 | Toshiba Tecra A3 Notebook
No boot. Continuous long beeps
Remove the following one by one: 1. RAM. Reinsert and reboot. 2. HDD cable (both from the motherboard and from the HDD side). Reconnect and reboot. 3. Power cable from the mother board. reconnect and reboot. 4. Processor. Reinsert and reboot. 5. The 3 connectors from the front basel to the motherboard. Reconnect and reboot.
Nov 05, 2009 | Abit KT7A (KT7A-RE) Motherboard
I have lost all icons on desktop, cd rom not
Sounds like your hard drive failed. Memory is cheap, so it's not an expensive fix and easy to do yourself with minimal skills. Once you open the case, there should be 4 screws holding the HDD in place, one fat ribbon type cable and one connector with 3 or 4 wires (power). You can just pop a new HDD in and reconnect and use your software disks to reload the operating system. Most computer repair shops can get the data off of your old drive and load it onto your new one.
By the way, you wouldn't happen to be a Limewire user would you? There seems to be a new trend connecting HDD failure and Limewire use. This is not yet proven but being investigated. It is likely not Limewire, but malware attached to downloaded media.
Oct 06, 2009 | Dell Dimension 2400 PC Desktop
How do I change the LCD screen please?
Very easy.
Remove the batery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Sep 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Hdd
The first issue is how you are connected. If it is IDE or SATA. Next is to ensure that the bios settings are set to enable the corresponding connection. Next ensure you have the cords or ribbons seated properly in the drive as well as the board, ensuring the power connection is secure. Good Luck!
Jan 28, 2008 | Maxtor Hard Drive
Computers & Internet Logo
19 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
