Question about Refrigerators
Fast freeze switch - Refrigerators
Freezer has a rocker switch which side should it normally be on s or o? I KNOW IT IS TO DO WITH FAST FREEZING.
When it's running to temperature, switch the switch. If the compressor turns off that's the normal position. If the compressor just runs and runs it's in fast freeze
Dec 13, 2015 | Freezers
Hi I lost my manual to my westpoint tropical chest freezer, and wanted to find out how the fast freezer switch works. Does it mean when i switch it off the freezer goes off? or is it just a switch to help...
Hi
Normally a fast freeze button is just that, it turns the compressor on permanently to freeze things down quickly.
I suspect that your run light is linked to the thermostat, and does not indicate that the freezer is turned off but that the temperature of the freezer is above the temperature set on the thermostat and the compressor is running to bring the temperature down. Once the temperature is at or below the thermostat temperature then the compressor will stop and the red light probably goes out, indicating the the freezer is at the right temperature.
It won't go out with the fast freeze on because to freeze food quickly the thermostat is by-passed and the compressor runs continuously.
Hope this helps.
Aug 25, 2014 | Freezers
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Manual for lemair freezer model fr-120v
I have the manual.
From the Left:
(1) The "!" is the red warning indicator - indicates if the temperature is currently lower than set.
(2) "I" is the green power indicator,
(3) "S" is the Yellow Fast Freeze indicator,
(4) "S" is the Fast Freeze switch/button,
(5) "I" is the Off/On switch/button.
(6) - with the coin slot - is the Temperature Regulator.
(I have mine 1/2 way around the dial.)
Sep 18, 2012 | Refrigerators
The freezer freezes two hard , there are 2 switches on it are they both suppose to be on?? one is orange and one is white.
Well hello...on your freezer...the orange switch is for "fast freeze" and should not be on constantly...only when you want to freeze items really fast.If you have it on...turn it off.Also do you have the temp control set at maximum...If so...try to reduce the seting by one number.If not...leave it as is.Give the freezer about 24 hours to re stablize.That should do it...also...you will notice a reduction in your electric bill as the fast freeze switch causes the unit to draw a greater amount of electricity..MAKE SURE the orange switch is off...I hope this was helpful....PEACE...
Jan 05, 2012 | Haier 7.3 cu. ft. / 207 liter Chest...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
