Question about Texas Instruments TI-5006 II Calculator
Ti 5006II frozen - Texas Instruments TI-5006 II Calculator
    New Friend:
I had the same problem. Solved it by pressing the D/# key (just below 5/4 key) and then pressed the P/NP key (not sure if I pressed them at the same time).
Also pressed the D/# key and 5/4 key.
In my case, the screen showed an 'E' lower left of screen, and the 'Print' and '5/4' at the top of the screen.
Hope this helps.
Posted on Oct 06, 2014
My ti-84 plus is frozen on the main screen. i can not use any of the keys.frozen screen
Something is shorted internally. You might be able to take it apart and clean it out, reassemble and try again.
Sep 13, 2013 | Texas Instruments TI-84 Plus Silver...
Ti-84 frozen
If your programs are archived you can remove the main AAA batteries without losing them. If they are stored in RAM they will be wiped out.
Just do not remove the Main AAA batteries and the button cell backup battery at the same time.
Feb 04, 2013 | Texas Instruments TI-84 Plus Calculator
Hello, my name is Lucas Matthews and I have a TI-89 that is frozen. The home screen is frozen and wont change. I have tried taking out the batteries and replacing them. Also, I have tried holding the ON...
There is a backup battery hidden under a cover in the battery compartment. Try removing all the batteries, including that one. Wait a little while, then put them back in. While you're waiting, apparently dust in the usb connector can cause problems. I don't know why, but it can't hurt to clean it out if it's dirty. If that fails, you can plug it into your computer, download the necessary software from the TI website, and reinstall the OS. If all that doesn't work, there might be a hardware problem.
Mar 02, 2011 | Texas Instruments TI-89 Calculator
It has a large E on the lower left side of the window and it will not allow entry of numbers, like if the power was off. It will only print a zero when I press the ON/C button. No other key except the...
Try clearing the memory with the MRC button a couple of times, then the ON/C. You can view and download the operators manual at: http://education.ti.com/guidebooks/printer/5006ii/5006ii.pdf
Also, disconnect the power and remove batteries for a minute. Check batteries to make sure they are good then replug in.
Good Luck.
Jan 19, 2011 | Texas Instruments TI-5006 II Calculator
My ti-89 screen is frozen and wont accept input
Remove the batteries and wait a minute or two. Put them back in and turn the calc back on and it should function normally. Check for stuck buttons as well, as sometimes they will cause the calc to appear "frozen".
Sep 30, 2010 | Texas Instruments TI-89 Calculator
TI-89 frozen disolay
Here's the procedure for a hard reset. Be aware that it will clear all RAM.
1. Press and hold the left-arrow, right-arrow, and 2nd keys.
2. Press and release the ON key.
Dec 07, 2009 | Texas Instruments TI-89 Calculator
Frozen Calculator
I am glad it worked for you but TI advises against removing the keypad while calculator is on. There is a possible loss of information.
Aug 10, 2009 | Texas Instruments TI-Nspire Graphic...
TI-84 Plus Calculator Frozen - Defragmenting
try taking out a battery; if that doesnt work, all four; if THAT doesn't work, take out the watch battery as well; if THAT doesnt work, take out everything and leave it overnight
Oct 11, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-5006 II Calculator Logo
109 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
