Question about Ovens
Faillurecode f06 on oven type 5h810x - Ovens
Who can supply parts for officiana star ovens in nz
going google and typing in officiana star ovens brings up a site called axial.co.nz that calims to have parts for that oven
give them a call on line or ring the company
if they can't help then type in what I did in google and there are other pages that you can call.
Aug 20, 2015 | Ovens Ovens
Why did oven light explode
It may have been defective or the wrong type of bulb was installed. Only certain types of bulbs are rated for oven use.
Mar 21, 2015 | De Dietrich Ovens
Viking oven F06 code
www.vikingrange.com/consumer/category/support
Jun 11, 2014 | Viking Ovens
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Remove glass oven door
The video on You Tube will show you how to remove your oven door. You may need to watch it all of the way through to see your type of hinge. The video shows four different hinge types which are common and so covers most oven models.
Oct 20, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door locked with code F06 - this was after it had been on self cleaning mode. any suggestions on how to open the door?
The unit has to be cool for the solenoid that powers the lock to open. If the unit is cool, unplug or switch the appliance off at the breaker. Problems after cleaning cycles are an extremely common occurrence. The heat often fries circuitry and causes all sorts of misery for consumers. If the oven does not reset, please look at your error code again. The codes are usually either 2 or 4 digits, not 3. I am not familiar with FO6, probably because the appliance is made for Spain? In any event, in the U.S., F0 is the electronic board behind the clock. Please try the unplug/power step and let me know if it doesn't work. Thanks.
May 18, 2010 | Whirlpool RBS275PD Electric Single Oven
My kenmore self cleaning oven , F06 error
first try to turn the breaker off and then back on and see what happens.let me know if this helps and what is the model number?
May 10, 2010 | Ovens
I need to take the door off - any ideas
A lot depends on the type of hinges fitted to your oven door.
Try this link, it should help you .www.youtube.co.uk
In the search box type, replacing oven door hinges
Please let me know if you were successful .
Thanks.
Barkencoa
Nov 25, 2009 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
