Question about Toshiba estudio 255 Copier
C 440 heater problem
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
Change thermistor
Posted on Apr 18, 2014
How can i Test defrost heater, Check refrigerant leak
Check the defrost heater by doing a continuity test across the heater element leads. An easy way to check for a refrigerant leak is to hook up an ammeter to the unit and check for amperage draw under normal ambient conditions. If draw is equal to or slightly above rated spec the refrigerant level is ok. If amperage is low then the charge is lacking and the compressor works less and uses less electricity.
Aug 05, 2015 | Fisher and Paykel Refrigerators
I have a 3phase electric motor 440 v amps.7.6 and drive thats 440
Allowing for start up current I would put a 16amp 3 phase breaker/trip in circuit. If this trips then use a 20amp.
Aug 01, 2010 | Heating & Cooling
Does a gemtech 40 + 5 mfd work with a comfortair
Hi, as long as the 40uf x 440 volts and 5uf x 440 volt capacitor are the same is what you are replacing, yes it will work. Don't replace this 40 uf x 440 volt with a 40 uf x 370 volt cap. Voltage and microfarads must be the same, brand name makes no difference or these numbers, only the uf and voltage. Must be a 40 uf x5 uf, 440 volt dual run cap. It will work if the unit you want to put it on calls for that cap. The comfortair is a 3 ton unit, just be sure it takes a 40x5x440 volt and it will be fine.
Shastalaker7
Jun 04, 2010 | Heating & Cooling
GREENSTAR HIGHFLOW 440 bosh floorstanding
your site says apprx 1hr however my kids were cold her in scotland also no hot water,, several hours later i googled the manual and bobs yer uncle ..it was fixed to much condinsation due to the weather being -5deg
so apprx 20min to fix it was sort of easy,, so i never got an answer back from you so service not provided ,,please insert paypal payment back in to
my account ..thanks george
Jan 02, 2010 | Desa International CBN30T Central Heating...
Need a motor to cannondale speed 440 2003
email me i have a 2002 speed motor...
Oct 15, 2009 | 2002 Cannondale E 440
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
Codigo sc 440 aficio 350 (fotocopiadora
Hello sir; SC-440 means main drive motor locked ,suggestion; 1, check the connector isn't connected, 2, replace main motor.
May 06, 2009 | Ricoh Aficio 450 Copier
Engine swap: 440 into a '97 ram sport 2wd
use the 440 mounts change the frame mounts too 440 frame mounts
Feb 27, 2009 | 1997 Dodge Ram 1500 Club Cab
Toshiba estudio 255 Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
