Question about Quadstep Stair Climbing Aid
How can I buy the quadstep stair climbing aid?
I am trying to find it and purchase 2 for my elderly parents.
Is there a good basic first aid book that I can buy for my parents to keep at home?
Here is just one of the many books that Amazon are selling to teach basic first aid. http://www.amazon.com/Docs-First-Aid-Guide-Before/dp/0982713193/ref=pd_cp_b_3
You should use the 'view inside' feature to take a look at the book and see whether you like the layout visually etc before you buy.
Feb 28, 2013 | Health & Beauty
Trying to purchase a replacement parent handset for SCD520?
You can't. I just called Philips and apparently if the parent monitor stops working for whatever reason after the warranty has expired, there is no way to send them off to be repaired and no way to purchase a separate parent model. You are STUCK with buying the whole package again. I have a perfectly good base, but the parent model got into the hands of the child and no longer works. The parent units have to be sold with the base. These parent units are so vulnerable; can't believe there is no way to purchase a replacement. No happy with Philips.
Feb 05, 2011 | Philips Avent Scd520 Dect Baby Monitor
Samsang Tv turns off and on all will.........do we have ghost?
Symptom shows that Lamp is weak and requires replacement.
How old is this TV and have you replaced its Lamp yet?
Apr 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Old freezer in basement
eihter your renting an appliance handtruck ( has stair climbing ablities), or your cutting up in peices and carrying out
Jan 31, 2009 | Freezers
My elderly parent purchased a new tosheba fridge 2 months ago. the fridge failed on Tuesday and approximately $150.00 woth of frozen & fridge stock was lost. Today Thursday the fridge is not repaired...
I didn't even know that Toshiba made refrigerators. All major manufacturers nowdays have spoiled food insurance to at least 300 dollars. I would contact customer service at Toshiba and tell them you want the unit fixed within 2 days or you will return the unit for a refund.
Oct 23, 2008 | Refrigerators
Problem getting out a level
Mission Three: Union Station
Head through the hall and up the stairs and you will come out to the train yard. Hang a left and then enter the open door on the train. Go through the car and kill the enemies that appear and head out the other side. Enter the large building and a scene with more Kestrels will play. After the big bang, you are in for a tough battle with another Kestral and a few armed punks. After you get Kestrel down to the ¼ health mark, she will take off to a platform high above. Head forward to the ramp leaning against the train and climb it. Go left and slide across the rail to the train across from it. Make a left and run to the end of the train and jump to the pole. Swing to the pipe and climb up. Back jump to the next pole and swing your way over to the platform Kestrel is on.
After the scene, head back down and across the ground to the doorway on the far side at the other end. Enter it and follow the hallway through until you reach the set of stairs on the other side of the sprinklers. Follow the stairs up and then follow through the hallway until a scene plays that shows a catwalk collapse. Head up the stairs there and take out the punks and then make a right at the top to head up more stairs. When you reach the top, swing across the bars to the next platform and then halfway down the stairs. Jump to the staircase on the left and head up to the next platform and more poles to swing across.
Enter the vent at the end and follow it through to a large room you’ll drop into. When the Kestrel shuts the gate, you need to open it up. This part can get a bit tricky. What you need to do is toss a body into the electrical panels on each side of the door and make sure you have a body on each panel at the same time. When you do, the gate will open for you to go through. The easiest way is to use your hook and throw the bodies into the panels. You can try kicking them in but it takes a long time and getting two up like that will not work quick enough. Use the hook to throw them into them and then go through after it opens. Follow the opening in the wall around and through until you reach the staircase. Head up and take out the punks there.
Continue up the next set of stairs and make your way to the end of the corridor. Go through the door on the left and enter the hallway. Head left and drop down the hole at the end. Follow the next corridor along to a set of stairs and go up and up and up to the top floor. Head through the door and go up another set of stairs. Take out the punks here and then you’ll be in a room with a large window. After the scene hop through and head to the left and around the corner to the door there. Kill all the enemies in sight and then a scene will play as a guy comes through the door there. Kill him and then go through the door to trigger another scene.
Head through the door on the left after the scene and head through the room to the right. Drop through the opening and head down the stairs to the ground floor of the club. Look up to the right and there will be a large neon sign that says Strages. Target it and then toss up your hook to grab it and pull it down. When it crashes down, run through the door there and you will come to the dance floor. When the punks attack, you will need to toss one onto each of the four speakers in the corners. When you have a punk in each speaker, the dj booth will blow and you can escape the dance floor. Make your way up the stairs and again until you come to the floor with a doorway directly across from you. Enter there and take out the enemies inside.
Target the ceiling and then pull it down with your hook. Jump up the debris and head down the corridor to the opening at the end. Go to the fence directly in front of you and start wall climbing up to the top. Jump over to the closest scaffolding and take out the punk there. Go to the corner of it and rail slide down the pipe and again on the next one. Jump to grab the pole and swing over to the next platform. Make your way to the ramp and run down it to the catwalk against the wall. Run to the right and head up the spiral stairs. Kill the rest of the punks and then enter the gear room. After the scene climb up the pole in the room with your back away from the gear. Back jump off to the flat gear and land on it.
From there jump up and grab the pole and then swing over onto the next gear. Jump from that gear to the right and then from there to the pole above. Swing up the poles and then over to the gear beside the weight going up and down. Climb the pole with your back to the weight and wait for it to lower. Jump back on to it and ride it up. Now you will have a little scene with Ephemera. After the scene, you will battle her for a little while until another scene plays. After the speech Ephemera gives, the mission will end.
Aug 15, 2008 | Majesco BloodRayne 2 for Windows
Quadstep Stair Climbing Aid Logo
37 people viewed this question
Top Quadstep Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Quadstep Exercise and Fitnes Expert? Answer questions, earn points and help others
