Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
How to repair and service elna 2800 sewing machince free
Machine skip all stitches do not sew. I have changed needles, do settings, nothing help.
  • Singer Master
  • 1,388 Answers
Good luck
Posted on Apr 22, 2014
textile
  • 10 Answers
SOURCE: I have an Aldi Delta
sarah if the top tension is to tight it might slip stitches but as always when there is a problem with stitching you should change the needle and make sure it is in right.
Taking the needle plate of and cleaning with a fine brush around the bobbin and feeders will help and should be done regular.
Posted on Aug 19, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
Posted on Mar 28, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
I have an old elna sewing machine and it started skipping stitches badly I noticed when rethreading it does not want to pick up bobbin thread.plz help with info .Nicole
indicates a needle /hook timing issue
check for correct needle and that he needle in in correctly
possible that the needle tread tension is too light
Feb 11, 2018 | Elna Sewing Machines
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Feb 24, 2017 | Elna Sewing Machines
Slant o matic 401g skipping stitches what is wrong
Make sure you are using a brand new needle. A damaged needle will frequently cause skipped stitches. (Changing the needle is the least expensive repair for machine problems!!!!)
There is a lot of information available on the internet.
10 reasons for skipped stitches
Nov 17, 2016 | Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
Here What to Do if Your Sewing Machine is Skipping Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
I have a Elna 6003. Recently I started having problems with the stitches skipping, and the machine was making a clicking sound. Now I have discovered that the needle is hitting inside the bobbin case and I...
skipping stitches can be the needle is damaged--flat side of needle goes to the back side of machine
normally when the needle is hitting the inside of the bobbin the timing is usually off, & can only be fixed by a sewing machine repair tech
Jan 31, 2012 | Elna Quilter's Dream 6003Q
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Jan 31, 2008 | Elna 2007 Mechanical Sewing Machine
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
23 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
