Question about OKI B6500 Led Printer
OKI ES7120 loading on LCD display - OKI B6500 Led Printer
Needs firmware upgrading
Posted on May 14, 2014
How to reset Oki 720 to factory default
Okidata B710 and B720 Maintenance Reqd. Reset Procedure
To enter the Diagnostics area:
Turn the printer power OFF.
Press and Hold the MENU^ and Enter buttons.
Turn the printer power ON (you can release these buttons as soon as "loading ... '' is displayed.
The Operator Panel reads "Diagnostics"
There is a list of Test Options and settings.
Press the Down Arrow highlight "Maintenance Info." Press the Enter button
The Operator Panel Display reads "Maintenance Info" with setting listed.
Reset Maintenance reqd. is highlighted. Press Enter
Reset Maint. Reqd. is displayed and Execute is highlighted.
Press Enter.
The Display reads - Resetting Maintenance Required.
This completes the process.
Dec 23, 2015 | OKI Office Equipment & Supplies
How fix oki B6500 loading display error
gravity reset. seriously, hold it about 9" off the floor and drop it evenly. repeat if not fixed. this was in an oki tech bulletin. there is a ribbon cable deep inside that comes unseated. unless you want to take the ENTIRE printer apart perform the steps above. :)
Aug 19, 2014 | OKI Office Equipment & Supplies
How to check ink levels on oki mc361?
Press the STATUS button on the operator panel. This will display the toner levels on the LCD screen
Nov 26, 2013 | Oki Electric Industry Office Equipment &...
I have oki b710 and only loading... message is displayed but nothing else happeness printer doesn't initialize.
I called this number - 1-800-654-3282 available 24/7
and they have steps
1. Turn off the printer
2. Press the "menu" and "online"
3. Press until the screen says - "Format User Flash"
4. Press "enter"
5. Restart printer when prompted
Apr 11, 2012 | OKI Printing Solutions B710dn Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
OKI c3200n "COMMUNICATION ERROR"
try switch off, unplug, hold up and down & reset button at the back, swith on
Jan 30, 2009 | OKI C3200n Led Printer
Okifax 5750 baud rate
Try the following with the machine in standby mode. (no document fed)
Press MENU/EXIT key ONCE.
Press RESOLUTION key TWICE.
LCD display should indicate "Technical Prg."
Press DOWN ARROW key ONCE
LCD -display should indicate "2 Setup"
Press RIGHT ARROW key ONCE
LCD display should indicate "Setup"
Press the DOWN ARROW key TWELVE times.
LCD display should indicate "13>H/Modem Rate"
Press the RIGHT ARROW key ONCE.
*** NOTE WHAT IT IS ALREADY & DO NOT FORGET IT IN CASE YOU WANT TO UNDO ***
Press the DOWN ARROW key repeatedly to change the setting to 4.8, 9.6, 14.4, 28.8 or 33.6K.
For "9400" set it to "9.6" (9.6K = 9600 Baud)
Also note that for this to fix your problems I would expect to find your machine is currently set to 14.4 or higher.
Change it and see how it works for you. If it is no good, you can always change it back to the original setting.
Sep 05, 2008 | OKIFAX 5750 Plain Paper Fax
OKI B4300 Change paper
please keep the papers correctly aligned so that the sensors will recognize it...
good luck!!!!!!
dont forget to rate this
Aug 21, 2008 | OKI B4300 Led Printer
Oki B4300 LCD printer
Error 020 is a CU ROM Hash Check Error 1
It's most likely in need of circuit board replacement
If it's under warranty, contact the seller or
call 1-800-OKIDATA
Apr 05, 2008 | OKI B4300 Led Printer
Oki Data Series 5000
This is a PS Can't Happen Failure and occurs when an error has been detected in the PostScript core.
If an address is displayed on the LCD, note it down for future reference.
Restart the printer and it should be cleared.
Oct 11, 2007 | OKI C5400tn Laser Printer
OKI B6500 Led Printer Logo
219 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
