Question about Canon DR-2050C Path-Through Scanner
Capture perfect 3.1 - Canon DR-2050C Path-Through Scanner
Can't change dpi or mode in scanner settings on capture perfect 3.0
Remove & re-install 9080 driver & Capture Perfect if the driver doesn't fix the issue. Verify you have Administrative rights to the computer as well
May 21, 2014 | Canon DR-9080C Path-Through Scanner
Sony DCR-TRV19: New capture problem
Hello, please try with changing the compression data rate. Best regards, Arpi
Aug 19, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Apr 03, 2014 | Canon DR-2010C Flatbed Scanner
I need vedio capture driver for ati wonder tv tuner
The video capture software is already included in the CD that comes with the Video capture card... But if you needed an alternative software, try Ulead Video Studio 7, works perfectly on me.
May 19, 2011 | ATI TV Wonder Video Capture
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
Nov 12, 2010 | GE 98090 Webcam
When I copy a film from my camera to my computer I couldnot get the voice( the audio)part , only the movie transfers how could I transfer both. Even if I connect it perfectly I couln't hear the voice only...
Dear sir,
Welcome to fixya customer Support
We will help You.
I think u r transfering movies or videos wrong way.Actual Procedure is Like this
1.First Connect the camera to the Video capturing cards or Ports of computer.
2.Open Video Capturing Application installed in your pc (comes along with Your capturing device)
3.then Play the videos in Your Camera
4. Then Start Capture in computer.
This is the actual way of capturing Videos to the PC.I think it helps
If it is not Just check the camera audio video jacks.Adjust the TV system(PAL or NTSC) in camera and PC.
If it is not solves u r Problem.Come back with further Information.
Good Luck
Thanking u
for Choosing Fixya Customer Support
Chandrashekhar
Jul 14, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Bad quality at capturing from nv gs15 with imovie
You can try VideoStudio version 9, I use this for all my video capture and the quality is perfect but you have to have a huge capacity hard disc if you want a very exceptional video quality. By the way, my sister gave me a camera like yours just last month but she lost the CD, just want to have a favor.... if you could send me a full copy of the CD for the NV GS 15. my email address is brielm99@yahoo.com. Thanks in advance.
Jan 02, 2009 | Panasonic NV-GS15 Mini DV Digital...
Scanner dint work
I purchased Canon DR 9080C scanner two years back but the CapturePerfect 3 not received. So speed is slow. Can Canon Big help me to provide capture perfect 3 software. My email is prakashkhedekar@gmail.com
Jun 07, 2008 | Office Equipment & Supplies
I have VISTA, A DR2580C and Capture Perfect 3. When I select Capture 3 a message comes up "Scanner is not found check cable" I previously installed Capture Perfect 3 then upgraded it using the Cannon...
Hey...dont get me wrong...we all make mistakes...am sorry again for that mistake...
if you are intrested try this way again...
> goto device manager > right click that is yellow > select uninstall driver > and repeat it to the other named something scanner
and > do again the installation again (what i told you in chat) for all yellow flags > restart windows >
ask me any prob at my profile? Roshan89...
May 21, 2008 | Canon Office Equipment & Supplies
Scanner command invalid in current state
I have not used CapturePerfect 3.0. Hope the scanner is just fine. Try count only mode to check if it is okay.
Uninstall Captureperfect. Run chkdsk/scandisk to check if OS is ok. Reinstall Captureperfect again and it should work.
S. Mohan
Jan 31, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-2050C Path-Through Scanner Logo
148 people viewed this question
old marine
old marine
