E.F.I. monitor warning light does not illuminate when key is turned on
2 Suggested Answers
mosthated357
  • 91 Answers
SOURCE: Check engine light not functioning
What you need to do is either check the fuses but more likley if you have a car with that much wear and tear the you have 214k on it the little led lite bulb is prob just burnt out you can replace it yourself or if your a good customer to a garage they would probably just do it for free i used to all the time.. You can get the bulb from advance or auto zone for 3 bucks if you need any other help or just information on how to change it let me know id be glad to help also please rate me if you get a chance..
Thanks, Steve
Posted on Jan 03, 2009
2003 Ford ka what colour is the wire for the alternator warning light on dash cluster
There isn't one ! This vehicle relies on serial data communication . The PCM sends an message on the data bus to the microprocessor inside the instrument cluster . The PCM controls the operation of the charging system warning indicator in the instrument cluster. The PCM is therefore responsible for turning the warning indicator off after the engine is started and illuminating it under fault conditions (when the generator is not generating the correct amount of current with the engine running). The warning indicator will also be illuminated by the PCM at key ON engine OFF, and stall conditions.
Charging System Warning Indicator
The instrument cluster receives the charging system status from the PCM over the SCP or CAN communication network. The PCM controls the charging system and the charging system warning indicator. The PCM is therefore responsible for turning the lamp off once the system is running and illuminating it under fault conditions (including stall conditions).
How to Diagnose Controller Area Network CAN Your best bet would be to take your vehicle to a qualified repair shop .
Jun 23, 2016 | 2003 Ford Focus
I have a 2002 mazda 626 when i get in to start it the lillle light that looks like a car with a key in it flashes then gos of
The car and key looking light are immoblizer or security system warning. If it illuminates briefely with the other dash warning lights when key is turned on and then goes out it is just performing a bulb check. It light remains illuminated, flashes, or vehicle will not start with either conditions of the light then your security system has been activated. The system is looking at a computer chip that is built into your key. If chip signal does not match one that has been programmed to start the vehicle then it will not start for anti theft purposes. Any new keys need to be programed with an external computer to start the vehicle. Interference with key signal can occur if on a key ring with other keys from other cars or same car that has a chip. Remove from keychain if using a key that has worked in the past.
Nov 11, 2015 | Mazda Cars & Trucks
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Reset change oil light
Driver Information Center (DIC) Equipped
Step 1 of 5
Place the key in the ignition and then turn it to the On/ACC position with the engine off.
Step 2 of 5
Press the "mode" button on the DIC until "Oil Life Left/Hold Set to Reset" is displayed on the DIC screen.
Step 3 of 5
Press the "set" button and hold it down until "100%" is displayed on the DIC display screen.
Step 4 of 5
Wait until three brief chimes emit before turning the ignition key back to the off position.
Step 5 of 5
Start the engine of the Aztec to ensure the oil warning light ("Change Engine Oil") is no longer illuminated on the instrument panel. If it still is, repeat the procedure.
Non-DIC (Manual Change Oil Light)
Step 1 of 4
Insert the key into the ignition and turn it to the ON/ACC position with the engine off.
Step 2 of 4
Step on the accelerator pedal fully to the floor three times within five seconds.
Step 3 of 4
Turn the ignition key to the off position.
Step 4 of 4
Start the engine to ensure the oil warning light is no longer illuminated on the instrument panel. If it is,repeat the procedure.
Aug 22, 2013 | 2003 Pontiac Aztek
New key programming for lancer 2005
you need to first install one of factory key into ignition.turn ignition switch on position for 5 seconds.switch off the ignition and remove key.wait 7 seconds insert new key into ignition switch.and switch ignition on until alarm system warning lamp will flash twice mean key programmed. switch ignition off if warning light illuminate for 3 seconds to confirm or flash 3 times indicate registration has failed. if you fail on programming new key let dealership reprogram new keys using diagnostic equipment.
Dec 20, 2012 | 2002 Mitsubishi Montero Sport
What does an ! in a circle mean with ( ) around it
This (!) symbol is your TIRE PRESSURE MONITORING SYSTEM (TPMS) warning light.
The manual has this to say about it:
This system monitors tire pressure. if the low tire pressure warning light illuminates, check the tire pressure in all four tires. Adjust the low tire pressure to the recommended cold tire pressure shown on the Tire and Loading information label located in the driver's door opening. After tire pressures are adjusted, the vehicle will need to be driven at speeds above 16 MPH (25 km/h) to activate the TPMS and turn off the low tire pressure warning light.
Mar 02, 2011 | Nissan Pathfinder Cars & Trucks
I used the wrong Honda key in my 07 Odyssey. The ignition is disabled.How can I fix,
PUT THE RIGHT KEY IN THE IGNITION SWITCH TURN IGNITION SWITCH TO ON POSITION UNTIL IMMOBILIZER WARNING LAMP ILLUMINATES FOR FEW SECONDS.KEY HAS RESET.IF IMMOBILIZER WARNING LAMP FLASHES RAPIDLY KEY DID NOT RESET.TRY TURN SWITCH ON WITH KEY UNTIL IMMOBILIZER LIGHT ILLUMINATES FEW SECONDS TURN OFF YOU READY TO GO GO GO.IF CANT RESET HONDA DEALERSHIP HAS TO USE DIAGNOSTIC EQUIPMENT TO RESET KEYS TO IMMOBILIZER MODULE.
Nov 07, 2010 | 2007 Honda Odyssey
I have a new battery but my car would not start, but passenger real window rolled down by itself and the dash lights would come on and go off with or without the key in the ignition. Does anyone know of...
TRY PUTTING KEY IN IGNITION SWITCH.TURN SWITCH TO RUN POSITION THE IMMOBILIZER WARNING LAMP WILL ILLUMINATE A FEW SECONDS.KEY CODE IS RECOGNIZED.IF IMMOBILIZER WARNING LAMP ILLUMINATES FOR A FEW SECONDS THEN FLASHES RAPIDLY KEY CODE NOT RECOGNIZED.TRY IT AGAIN FROM THE ABOVE INFORMATION.IF CAR STILL WONT CRANK.THE DEALERSHIP HAS TO REPROGRAM IT FOR YOU.
Feb 15, 2010 | 2005 Acura MDX
How do you turn off the airbag light on the right side of a 1999 volvo s80?
According to the manual, that warning light will illuminate if a fault is detected. Normally, the SRS warning lamp should light up when the ignition key is turned to positions I, II or III and should
go out after 7 seconds or when the engine is started.
· If the SRS (Supplemental Restraint System) warning light stays on after the engine has started or if it comes on while you are driving,
drive the car to the nearest authorized Volvo retailer for inspection as soon as possible.
Hope this helps.
Jul 08, 2009 | Volvo S80 Cars & Trucks
There's a flashing light on my dashboard, it's an orange light outline of my Beetle with a key in it. Please can you tell me what this means?
That symbol stands for Electronic Immobilizer. Here's a summary of what the manual has on it... When the ignition is switched on, an automatic key data test takes place. The data test is confirmed when the warning light illuminates and then will turn off after approx 2 seconds. However, if a non-authorized key is used, the warning light will blink continuously and it says the engine will not start.
Jun 25, 2009 | 2005 Volkswagen New Beetle Convertible
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
