Question about Sharp el-531x scientific calculator
How do you use the fraction button - Sharp el-531x scientific calculator
  • Sharp Master
  • 8,064 Answers
The fraction button is usually marked [a b/c]. Its shifted function [d/c] converts a mixed number into an improper fraction.
To enter a mixed number, say 7 3/5
Enter 7, press the [a b/c] key, enter 3, press the [a b/c] key, enter 5. Press =/EXE
Posted on Mar 18, 2014
Fraction to decimal
Press the S<->D button located just above the DEL button.
Oct 14, 2013 | Casio fx-300ES Calculator
How do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
Jul 07, 2010 | Sharp EL-501WBBL Calculator
I can't find this button on my calculator / this
A fraction is in fact a ratio of two number: a division of a numerator by a denominator. The key used for the division operation is the one above the multiplication sign and below the caret [^], and in thee rightmost column of keys.
Beware that this calculator converts any ratio of two numbers into a decimal value. To keep a fraction in a fraction form you must use the [|=>Frac] or [ToFrac] command. To convert a decimal result to a fraction, use the [|=>Dec] command.
These commands are accessible through the CATALOG or more easily by pressing [MATH] (under the ALPHA key) and selecting [1:|=>Frac], or [2:|=>Dec]
Ex: to keep 27/48 in fraction form you enter
27 [/] 48 [MATH][1:|=>Frac] [ENTER]. Result is 9/16
You will notice that the resulting fraction is reduced to its simplest form.
To convert the above result from fraction to decimal press [MATH][2:|=>Dec]
A fraction can always be approximated by a decimal value but the converse is not always possible.
Jan 23, 2010 | Texas Instruments TI-84 Plus Calculator
Can't find fraction button.
There is no fraction button, but if you divide two integers (whole numbers) and want to keep the result as a fraction press [MATH][1:|=>Frac] [ENTER]. If the fraction can be reduced to its simplest form that is the result you will have.
27/48 [MATH][1:|=>Frac][ENTER] displays 9/16
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
How to convert fraction to decimal
You can convert between Standard Form (with fractions and pi) or Decimal form by using the "S<->D" button. Use Mode 1 if you mostly prefer fraction answers and you can use the SD button to convert to decimal or use Mode 2 if you mostly prefer decimal answers and use the SD button to see the fraction.
I hope this helps and good luck!
Please remember to vote 51218db.jpg Thanks.
Oct 31, 2009 | Casio FX-115ES Scientific Calculator
Fractions
there is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
May 05, 2009 | Casio FX-300MS Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fraction button directions
Yeah, there isn't a fraction button on an 84. You have to enter it manually as 4/9 or if simplifying a decimal, use the Ans>Frac under the MATH menu
Aug 26, 2008 | Texas Instruments TI-84 Plus Calculator
Sharp el-531x scientific calculator Logo
156 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
