Question about Maytag Washing Machines
E3 ode pro freeze
I have ps3 e3 ode pro , problem is when i play the game(any game)1-5min it freezes whole system of ps3 HDD's light is OFF when it freeze
bubulica2000
  • 55 Answers
SOURCE: PS3 Freezing Mid - Game
Madden 09 itself has a lot of issues. EA is supposed to come up with a patch to fix the freezing issue for Madden 09.
There are a lot of unhappy madden 09 owners outh there.
As far as freezing on any game that sounds like a bluray diode issue or overheating issues.
keep the console in a well vented are (maybe even add a small portable fan from walmart that can help cool down your system.
Posted on Sep 02, 2008
SOURCE: ps3 freezes on all games
i have the same problem...
Posted on Nov 23, 2008
  • 265 Answers
SOURCE: PS3 freeze
hey guys i fixed this...
its over heatings the CPU and GPU
you need to disassemble it... http://www.llamma.com/PS3/repair/PS3_disassembly_tutorial.htm
then you need to replace the thermal compound with artic silver 5 as the stuff sony has put on is very dry and cracked, i have done this 4 7 of my mates PS3'S and they all work fine.
only do this if its out of warrently, if you removin the sticker on it, it shines through void
Posted on Feb 16, 2009
  • 30 Answers
SOURCE: freeze during gamplay
PS3 is one of the most amazing gaming device but like other Competitor. gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up..
Posted on Feb 21, 2009
  • 133 Answers
SOURCE: PS3 freezes...shows colored "specs" on screen.
This is a common problem with the PS3. sadly you cant do anything for it. The only think you can really do is to get your PS3 replaced cause sadly your PS3 has suffered dome physical damage for sure.
Posted on Mar 25, 2009
Ps3 keep freezing
Have you tried to reset / update your PS3? Try installing the game to your HDD, as well
Nov 09, 2013 | Video Game Consoles & Games
My PS3 freezes whenever i play a game, but i can watch movies with no problems. whats going on
hi there,
it sounds like your ps3 is overheating, this happens more often with games cause they use more graphic power than a movie does thus causing the gpu chip to overheat and freeze on you. It could also be that your hdd is not slotted in fully and this can cause it to freeze also. what you can try is to make sure the fan at the back is well ventillated, clean it of any dust and make sure that its working. remove all cables too and check that none of them are damaged and make sure they are connected properly to the ps3 and tv. Do not play a game for at least half hr after you have done all this, just to make sure it's cooled down and put your ps3 in an open space to allow plenty air to get in at the back if you have not already done so. if the console is still freezing when you try it again, then try removing the hdd and put back in again to see if that's what is causing the problem. Be sure to backup any data on the hdd 1st tho as you will loose this if you going to remove the hdd. you can use the backup manager on the ps3 itself to do this. Hope this helps
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
My ps3 keeps freezing during the game
fix your PS3 so that it turns on again...
now the only reson there is 6 videos is because this one is a complete guild from tear down to rebuild... follow it exactly and you should be fine.
Jul 23, 2010 | Sony PlayStation 3 40GB System
Game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
My PS3 freezes at the setting screen or once control is turned on
OK, I never encountered this issue before, so it's either the system files that corrupted or a hardware issue.
First try the following: Switch the PS3 off (Red Light). Hold your finger on the power button until the PS3 switches on and off. Take your finger off and hold it in again. It will come on. Hold it until you hear a double beep and take it off immediately. You will then be taken into a recovery menu. It will ask you to connect your controller via USB. Choose option 3 - Restore File System (Do not try any other option as it will erase some or all data on your HDD) It will also give you a message that the file system is corrupted. Just go through it and continue the restore.
If this does not work, you should try another controller or worst case, format the HDD.
Hope it helps.
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezing
clean the discs because if it has finger prints it freezes that happen to me in gta 4
Jul 05, 2008 | Sony Playstation 3 (PS3) Console
Ps3 keeps freezing
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Ps3 console freezing during game
check your HDD of ps3,is it full of memory cause for your kind information there is a program when ps3 needs more memory than its creates short time developed cash as memory on HDD so, if you ahve full HDD than reate some blank space on HDD for memory for barer performance,
i hope so you got mine idea,
if you still have problem than try to contact me .i illl....
THNX
May 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 freeze
look on Sonys website for patches et,c.
Sometimes they launch games, and realise that theres glitches.
they then create patch-files which you can usually download, to update your console.
if this does,nt work. then you,ve possibly got a faulty game.
Exchange It.
Mike @ Compurepair.
Feb 22, 2008 | Sony Playstation 3 (PS3) Console
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
