Question about Nakamichi Audio Players & Recorders
Power lead on nakamichi dr3 cut - how to refix?
  • Nakamichi Master
  • 1,267 Answers
This is just a matter of take the cover off, taking out the strain relief and getting a new cord of the same thickness or the same cord is just jut and then soldering the ends to the places in the unit where the old cord went and then fitting and remounting the strain relief. I have done it on all kinds of decks many times in 40 years.
Posted on May 07, 2014
How do I connect a turntable to my nakamichi av-8?
This model does not seem to have a dedicated phono socket on the back. But you can connect it to the AUX socket. However in order to get any volume out of the deck. You will need to pass it through a magnetic cartridge pre-amp first. You should be able to pick one up at places such as Amazon. You plug the deck leads into the pre-amp and then the out leads into the aux socket of the av-8.
Apr 03, 2016 | Nakamichi AV-8 Receiver
Would a nakamichi soundspace 8 subwoofer work on a soundspace 9. I think the power is the same. Thanks Hugo
Nop, don't do that, the subwoofer power in the Nakamichi Soundspace 8 is 20 Watts and the subwoofer for Nakamichi Soundspace 9 is 70 Watts. If you put the 20 Watts Subwoofer on a 70 Watts input the subwoofer will receive severe damage. http://www.nakamichi.com/pdf/SS8_brochure.pdf
http://www.nakamichi.com/pdf/SS%209%20Brochure.pdf
Jan 29, 2016 | Nakamichi SoundSpace 9 CD Shelf System
The power lead on my nakamichi dr3 is cut, how do I fix it?
If the power cable goes inside the unit, then all you need to do is open up the unit and trace back the wire to where it connects. It will only be soldered on. You can buy a suitable power cable from most electrical stores.
Mar 18, 2014 | Nakamichi Audio Players & Recorders
Improper shut down
try to refix ram,remove ram clean ram and refix it.If its not ok then remove wifi card and switch on laptop with out wifi card.if the laptop is shutting down with out wifi card then clean the lead of wifi card and refix wifi card and if the same problem persist try to update bios with out wifi card and check with wifi card connected back again.If the problem persist replace wifi card.Follow this link to refix ram in that vedio http://www.youtube.com/watch?v=Q1m0SBQu7iU .Follow this link to refix wifi card http://www.youtube.com/watch?v=54VS4bFM-qI
Jan 12, 2014 | Dell Inspiron 15 (N5050)
Have had a Nakamichi Sound Space 1 music stereo system for 10 years. Has served me well but the other day when I turned on the wall switch the power light did not come on. have tried...
you should always check the plug 2 all your thangs an change them if they are faulty. try 2 plug it in someware eles. or the unit is done. somethang could be burnt out. dnt leave it plug in.and dnt plug it in 2 a multi plug. go staight 2 the wall to check any power problems.
May 10, 2011 | Nakamichi SOUNDSPACE 1 CD Player
I moved and lost the power cord. Where and how can I get a replacement cord?
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Feb 18, 2010 | Nakamichi SoundSpace 8 System
Power supply unit for nakamichi soundspace 5
we are the distributer for Nakamichi in India. Please call +91 9871371720
Jun 29, 2009 | Nakamichi SoundSpace 5 Shelf System
Nakamichi Sound Space 8 System
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
49 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
