Question about Bosch Audio Players & Recorders
Bosch wireless reciever MW 1-RX-F1 no lcd light does not respond to microphone. The other one with lcd light on can respond to microphone. Any idea what is wrong?
Reciever detailed above has no backlight anymore and its not responding to microphones. All settings can be done. But the green lcd light does not come on and the microphone is not receiving. The other receiver with lcd light can work well. I realy think its the lcd thing. But help will be hihly appreciated. Thanks in advance
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 148 Answers
Try checking batteries on microphone
Posted on Mar 18, 2014
SOURCE: Display Problem for Philips FR951PBK01 receiver
hey i own it too mine same thing but when i turn mine on i use the selector and the display comes back on so push power then spin the selector knoby thing it should work
Posted on Sep 22, 2007
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE: Att uverse remote won't turn on yamaha reciever
Do an automatic search for your code.
  1. Turn on the device you wish to program
  2. Point the remote control at the device
  3. Press and hold the mode key (i.e. tv, dvd or aux) you want to program
  4. Without releasing the selected mode key, press and hold the OK key simultaneously
  5. Release both the mode key and the OK key -All the modes keys will flash twice indicating programming mode
  6. Enter 922 by pressing the number keys on the remote control -The selected mode key will flash twice indicating correct entry (for anything other than AUX go to step 7, for the AUX mode searching only, press and release the play key then press 1 for VCR 2 for Receiver/Tuner 3 for Amplifier or 4 for Home Theater In The Box (HTIB) - The AUX mode keys will flash twice indicating correct entry)
  7. Press and release the PLAY key, every time you do this, autoserach will try a different code, continue to do this until your device turns off. (if you weren't paying attention and you miss it, the REW key can be used to go back through the codes one at a time, and the ff key can be utilized to move forward through the codes one at a time.)
  8. To save the code press the ENTER key (below the number 9) then press the exit to return to normal operations. (the selected mode key should flash three times
  9. Turn you device on by selecting the appropriate mode and power.
Posted on Feb 02, 2009
petraman7
  • 1175 Answers
SOURCE: i need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Posted on Feb 04, 2009
SOURCE: Reciever Shutting Down
I replaced R916 with a 10 ohm wire wound resister and that fixed the problem on the unit I have. That resister is in serise with R 915 so they should be close in value. Both were marked 8 ohms but tested about 11 ohms on R915 and the bad one tested very high (over 1 meg) so I replaced it. When I first put it back together it didn't work but I noticed that the ground screw at EP901 was not retighted so be sure that all ground screws are tight and all conections are redone before testing with the power cord.
Good Luck,
Thomas
Posted on Aug 06, 2009
I use MacBook Pro (OS X version 10.5.8) in combination with LCD TV, wireless mouse and new Apple wireless keyboard. The problem is that function keys of the wireless keyboard do not respond in a same way...
Make sure to run all available software updates as there's probably a firmware update for your keyboard you need to download.
If there isn't or the problem persists afterwards, you'll need to go into Apple Menu > System Preferences > Keyboard and Mouse > Keyboard and uncheck 'Use all F1, F2 etc. keys as standard function keys.'
Nov 06, 2010 | Apple Wireless Keyboard
Cant get sound from wireless system what are some possible problems
It's depending on the brand you're using.
But for general you have to check your;
Battery
Frequenty of the handheld, same as reciever
Frequenty of the receiver, same as the handheld
Gain adjustment in the handheld.
Gain on the receiver.
Check on the receiver if there's any RX when you switch on the handheld.
Good luck,
Gerard
Jan 29, 2010 | Gemini Audio Players & Recorders
What are the specs of a power adapter for an old Telex FMR-2 wireless reciever.
Check this out-including specs receiver. hope this will help ........................................
http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch%20-%20EV/FMR-450.pdf
Aug 08, 2009 | Telex FMR-500 Microphone
Wireless microphone receiver ready light or audio indicator nogo
It is definitely a Sync issue.
1) Make certain the microphone is ON and the light on it is green.
2) Remove the battery cover from the microphone.
3) point the **** end of the microphone (where it says Sync) toward the Sync button the receiver (about 6-8 inches away).
4) Press the Sync button on the receiver. You should notice the light on the microphone flash.
If this still does not work, call Shure Applications at 847-600-8440.
Aug 06, 2009 | Shure Audio Players & Recorders
Shure radio mic no sound
Call Shure Applications to help you troubleshoot at 800-516-2525, option 1. Have the wireless system and PA nearby when you call them.
Jun 04, 2009 | Shure SM58 Professional Microphone
Cordless Microphone fell pretty hard no output since then
hello i can not seem to find how to change channels on the wt88a kingdom wireless mic
Jan 25, 2009 | Zebra DM306 PROFESSIONAL WIRELESS...
How can i recieve normal telly
depends on what type of input your monitor has - if there is an rca socket [usually yellow] then you can take a composite video signal from a suitable set top box [via a similar rca socket or the scart]
Nov 22, 2008 | LG Flatron MW-30LZ10 30" LCD Monitor
35 people viewed this question
Top Bosch Audio Players & Recorders Experts
wayne-m
Bill Boyd
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
