Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Changing head on ryobi rlt3725 strimmer electric
I am trying to remove the plastic head from my machine to replace with a universal metal one. I cannot work out how to remove head.
    Problem Solver:
  • 6 Answers
Make sure all the screws are out you might have missed one. if you have them all out then VERY GENTLY pry it off, the gasket is probably just stick, if you still can't get it off go back and search for that last screw you forgot.
try getting on the mfg web site and look at the break down. to see what it shows make sure on doesn't come thu from the other side.
Posted on Jun 14, 2009
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
310x drive shaft and head replacement
Some of those nuts have opposite or left hand threads
Jul 11, 2012 | Garden
Ryobi electric strimmer rbc 1000ex would not start
hi guys ,i have a ryobi electric rbc 1000ex and i've only used it about 5 times since new ,blue light comes on , but wount spin ? any ideas ?
May 12, 2012 | Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
Need new plastic primer for multi purpose strimmer
any good small engins shor should have tthem all both walbro and zama you nrrd to know the bdand and modl of thr m schine that needs ij
Oct 28, 2009 | Ryobi Garden
How to remove the 'governor?' so that I can remove the plastic cover and replace the cord pull on Ryobi strimmer RPT2543C
What you are calling the "governor" is accutally the clutch drum. The is a screw in the center that needs to come out, then you will need to remove the clutch with a small punch and small hammer, by unscrewing it. Then you should be able to get to the recoil assembly.
Hope that helps.
Good day, mate.
Oct 23, 2009 | Garden
Small part fell out in grass and I can't find it. Where can I fi
They are called strimmer eyelets and most hardware shops, repair shops or hire shops will sell them
Oct 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Where can I get the two ferrules that sit in the trimmer exit housing. they are metal and allows the strimmer cable to come out and not affect the plastic housing? regards John
Check under yellow pages in larger city for a dealer for Ryobi or a place where they do tool repair especially industrial tool repair. These folks can get parts or may offer repair of same.
Or you might be able to make some if you knew the type of material and the dementions. A close materila may work out fine. If hard plastic and thin I wouild consider a detergent bottle to relign the surface with.
Let me know if this helps
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
521 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
