Pyle PLDN74BTI Car Video Player Logo
R
R Lowe Posted on Mar 18, 2014
Play back problems
I have the Pyle PLDN74BTI that can't seem to proceed from song to song and shuts itself down when I play from an SD card. Also, is there a way to set up playlists? The unit sets my music up in folders by artists and still has a tough time finding the songs. It just seems like I should have control of the playback modes when its not having malfunction problems. Thanks for any help
1 Related Answer
mra85008
  • 182 Answers
  • Posted on Jul 09, 2009
SOURCE: I have Pyle PLTDN71, everything is wired properly
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
Pyle manual pldn74bti
[email protected] ---- email and ask support- they will tell you-- lots luck
MUSIC I MOVED FROM COMPUTER TO SD CARD WILL NOT PLAY ON CELVIANO AP620 PIANO
http://support.casio.com/pdf/008/AP620_6_E_1A_web.pdf
E-48
Using a Memory Card
You can use the procedure below to play back a user
song (page E-24) stored on
a memory card without
loading the song into Digital Piano memory.
Memory Card Folders
Formatting a memory card on the Digital Piano will
automatically create the four
folders shown below. You
put playback song data into any one of the folders. You
can use the four folders to group your music data by
family member, genre, or some other categories. Use
buttons
through (folders) to select a folder.
1.Store the music data you want to play back in
one of the memory card folders.
2.Insert the memory ca
rd into the Digital
Piano's memory card slot.
3.Press the (CARD/INTERNAL) button.
4.Press one of the folder selection buttons (
through
) to select the card folder you want.
This will display the song number and song
name of the first song in the folder you
selected.
5.Use the (w,q) buttons to select the
song you want.
6.Press the (PLAY/STOP
) button.This will start playback.
•Each press of (PLAY/STOP) starts and stops
playback.
•Fast forward, fast reverse,
tempo changes, and other
operations are the same as
those during playback of a
user song in Digital Pian
o memory. For details, see
"Playing Back a Specific
Music Library Song" (page
E-24).
7.
To quit memory card data playback, press the
No power Pyle PLDN74BTI
Is your power cord plugged in? Are you using a power strip extension cord, if so check it to see if the power surge button hasn't been tripped. If so reset it. See if your wall outlet is working by plugging something else into it. If not working reset your breaker.
2answers
No picture on my a Pyle PLDN74BTI
bypass parking brake w/no switch codes
Help with seeing the video off my Pyle PLDN74BTI
bypass parking brake w/ no switch just codes for pyle pldn74bti car player
Prob. with detecting memory cards
hi can i reformat my nokia n73 pls help me thanks
Problem with SD card recognition
Try updating the firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/).
If your computer doesn't recognize the player, you'll have to turn it off, remove the battery and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
3helpful
10answers
My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Device keeps shutting off by itself and won't synch
Make sure the songs are in the right format. Napster is a real bear about disappearing songs - try another music svc.
Top Pyle Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
