Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Have MTd 42'riding lawnmower. It was running well, I turned it off the machine, took break and now it just clicks at the solenoid. I have replaced solenoid, battery, and now it still clicks. What do you suggest I do?
  • Ray McKinnon Jun 14, 2009
    I took the starter off yesterday and it appeared to be ok. I did not test it however. by jumping directly to the starter, are you talking about directly from the batttery to the starter?
  • Ray McKinnon Jun 16, 2009
    I hooked my starter directly up to my pick-up and it ran and mowed like a champ. I also tried turning the screen before that and it started. After mowing however, it went back to clicking at the solenoid again. I think maybe one of the safety switches may be bad. What do you think?
  • 376 Answers
Try jumping directly to the starter. If it still won't turn, try placing your hands flat on the screen and turn it back and forth sharply to try to dislodge the starter gear from the flywheel. They can, on rare occasion, get wedged in the flywheel and not turn. If none of the above work, I'd remove the starter and bench test it.
Posted on Jun 14, 2009
  • Dwain Pippen Jun 16, 2009
    By bench test I mean, hook jumper cables to it. With cables hooked to + and - on an external battery, hook the positive to the terminal the starter wire was attached to. Touch the negative to the mounting bracket. The starter should spin and throw the gear up. If it does nothing, check your connections again. If still nothing, your starter is defective.
Hi I have a Hasquvar mower . When i strt to release the clutch the motor starts dieing out. When i set the parking brake it stays funning any ideas
Posted on Jul 03, 2009
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
What type of oil do i use for a mtd yard machine 12.5/38 riding lawnmower?
Hi there. Use SAE 30 in temparature above 40 deg F, and 5W-30 if anticipated temparatures are below 40 deg F. You could also download your manual at http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1 just enter your model nubers in the center field and click dowload. Hope this helps
May 18, 2011 | Mtd Arnold Corp RearMounted Bagger for MTD...
I have had an electrical problem with this mower since ive had it. I have just changed the solenoid and switch and have looked at the wiring and switches all day and still nothing im getting power to the...
soliniod should have two small terminals one should get power when turn key to start position the other runs through ground curcuit which runs through break and pto switch most tractors wont start with out break switch working properly i would start with that first the i would go to pto switch. hope this helps
Aug 01, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman lawnmower lt 2000 42 deck which i tunded up last year and replaced the battery. this season i took out the battry and stored it in my garage. I recharged the battery and put it back in...
Try tracing the positive battery cable from the positive side to the solenoid
to make sure those connections are clean and tight. Then from the solenoid to the starter. Clean and tight. Last of all please check the Ground to frame connection.
Mar 11, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need a belt diagram for a husky 42 inch riding
If you have your model number and serial number handy, then enter both here to view available manuals.
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
I hope this helps.
DROPNDEAL
Jul 19, 2009 | Garden
Solenoid replacement
Can you give me the correct solution to conact a new Starter Solenoid to my Yard Machine 42" cut 16.5 HP Riding Lawn Mower?
Jul 09, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
596 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
