Question about Sony Cameras
Touch screen not responding
My Sony cyber-shot DSC-N2 has its touch panel not responding when tapped or touched with finger or any objects.
    Problem Solver:
  • 6 Answers
Use the mode switch the thumb button on the right right to get to the setup menu then initialize the camera to its factory settings this will enable the screen.
manual is here
http://pdf.crse.com/manuals/2887191131.pdf
Posted on Mar 18, 2014
welcomejee
  • 10594 Answers
SOURCE: sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Posted on Mar 23, 2009
PEye2000
  • 10 Answers
SOURCE: Sony Cyber-Shot DSC-W30. The lens is in a "stuck" position
You have a bad lens, it prob. also says turn off and on again.
Posted on Mar 26, 2009
ripleymojica
  • 643 Answers
SOURCE: my sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
go into setup menu and turn on the smile detection. go to photo and press the right arrow should have a pict of flash icon . press until the flash says auto.
Posted on Jun 03, 2009
AdiIngel
  • 87 Answers
SOURCE: Cyber-shot DSC-T70 Digital Camera: My Sony Cybershot dsct70 touch screen vibrates whe...
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Posted on May 26, 2010
hmerchant110
  • 7191 Answers
SOURCE: User's Manual for Sony Cyber-Shot DSC-S730
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Jun 12, 2010
Dsc-n2 langwich change
Touch "MENU", touch the toolbox-2 icon, then touch the "A" icon.
Dec 26, 2012 | Sony Cyber-shot DSC-N2 Digital Camera
I have pictures on my camera but not on a memory card how do i export them
images in the Internal Memory of the Camera can be moved to the Memory Stick with the COPY option in the Memory Stick Menu of the Camera. Follow the steps mentioned below for the information to select the COPY option.
Press the On-Screen-key to display the touch panel buttons.
Touch MENU to display the menu items.
Touch the Down Arrow button to select the MEMORY STICK Menu of the Camera.
Now select the COPY option and then the INTERNAL MEMORY option.
This will copy all the images in the Internal Memory of the Camera to the Memory Stick.
We wish you a happy Christmas and New Year!!
Dec 23, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
The screen on my sony dscn-n2 is broken where can i buy new screen?
Part number of lcd for Sony DSC-N2 is as follows:
A1151474A... TP BLOCK ASSY (30STGU05) (including LCD)
Available in Sony Part Store for $192
Thanks.
Apr 18, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
Need to display in other language
Press and hold the Index-finger on-screen key to display the Setup menu. Select the Toolbox with the digit 2 underneath to bring up the Setup 2 menu. Select the "A" icon to enter the language submenu, then select the desired language.
Mar 21, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
The touch screen will not let me change any settings in the menu
Sounds touch button array on LCD got disconnected due to over use or might have hard scratch on LCD surface, needs to be replaced LCD in your DSC-N2
Let me know if you can replace LCD in this camera to provide you LCD part number info.
Thanks.
Sep 20, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
White screen
turn off camera and tap it on the palm of your hand a few times this should work .hope this helps. jada.
Jun 29, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
My sony cyber super steadyshot model DSC-T70 flash does not work. Nosmile icon appears on the touch panel when shutter buton is pressed.
Jun 03, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Can't figure out how to change the pixel resolution on my camera
Touch the on-screen button(shows as a finger) to bring up the MENU, touch Image Size(two little squares) , select 1M (1280x960)
Apr 07, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Sony DSC T300. Problems with the flash
Hello!
I just solved this problem: to put flash, while you are in shooting mode, touch MENU, then REC Mode on the first page, and touch Normal, to take a single picture and then OK, you'll have the Auto Flash which appeares; but I never knew how to put the other kinds of flash...
Nov 03, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
Cameras Logo
67 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
