Question about NetGear WN2000RPT Repeater
I CANNOT BRING UP NETGEAR GENIE - NetGear WN2000RPT Repeater
How to reset password on Netgear router
Download NETGEAR Genie! The Genie will allow you to have complete access to you wifi
Jul 06, 2017 | NetGear Computers & Internet
Magnavox bluray won't connect with my netgear wnr2000 router
Check network access passwords or use network genie to allow network access if using access control
Oct 21, 2016 | NetGear WNR2000 Router
Trying to reset netgear genie default user name from admin
Admin may not be a permissible username as many companies ship theirs set as admin. Try a different user name.
Oct 16, 2016 | NetGear Computers & Internet
Can a hg568 router modem work with a netgear range extender and if so how do u get it to work
Might have a issue with the wireless. Suggest you connect both with ethernet. Using a netgear genie verify connectivity
May 01, 2016 | NetGear Computers & Internet
How can i install netgear genie n300 if i lost installation disk, i need to install netgear genie n300 wierless usb adapter to my windows 7 pc
This page: WNR2000v3 has Genie user manual, Installation guide, and the setup guide. It's the support page for Netgear.
Jun 20, 2014 | Computers & Internet
Wifi is turned off. How do I turn it on?
Stuart,
Some NetGear routers have a wireless button to enable/disable the wireless feature. Look for a wireless LED on the front of the router, if it is off check the back of the router for a wireless button. Press the button for 5 seconds to turn the wireless feature on/off. If that doesn't work you may need to login to the router to enable the wireless feature. Here's a snipet from the NetGear knowledgebase:
1. Type http://192.168.0.1 or http://192.168.1.1 in an Internet browser - some routers use the first URL while others use the second. If one of these does not bring you to the router's login screen, see If You Cannot Log on to Your Router.
2. Enter the user name and password; the defaults are admin and password unless you have changed them. NETGEAR strongly recommends changing the default user name for your network security.
3. Check Wireless Settings > Advanced > Enable Wireless Router Radio. For newer routers with a Genie interface, click on the ADVANCED tab > Advanced Setup > Wireless Settings > Enable Wireless Router Radio.
Note: You will need to uncheck two separate Enable Wireless Router Radio box if your router is dual band. One for the 2.4GHz and one for the 5GHz network.
I hope this helps.
Mar 15, 2014 | NetGear N150 / RANGEMAX 150 Router
NetGear WN2000RPT Repeater Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
