Question about Intenso 6002510 Memory Station 320Gb Usb 2.0 2.5 Inch External Hard Drive Black
When i plug my 64GB intenso memery stick into my laptop it does not read,the capacity of the stick is not shown and i cannot open the and retrive the files that are in it
When i click on the icon for my memory stick it says please insert a disk into drive E.IT USED TO WORK BEFORE,WHAT HAS GONE WRONG NOW?
    Master:
  • 397 Answers
It appears your drive has failed. I would recommend checking the USB drive is not damaged in any way, perhaps the USB plug on it needs re-soldering, I have had memory sticks in the past with the same issues which were cured by re-touching the solder bonds for the USB plug.
Posted on Mar 19, 2014
How to format memory stick Sandisk
Attach scansick memory stick to your computer
Double click on my computer
find your memory stick drive.
right click on the Memory Stick (MS) icon
choose format
click on quick format
click on start
click ok on warning appear
Aug 10, 2011 | Computers & Internet
Lexar 8GB wont work. when i insert it, it shows up on my computer as connected but then when i click on the lexar icon to view my files on it, it doesn't open, the message: 'please insert disk into drive...
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Oct 05, 2010 | Lexar Professional High-Speed 2GB Secure...
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Toshiba satellite memory stick problem
Oct 09, 2009 | Toshiba Satellite A135-S4527 Notebook
I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
Sep 06, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
Jun 02, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Oct 29, 2008 | Transcend (589307) Media
Unable to access files on SONY memory stick
Hello. Windows will automatically give it the next drive letter available whenever you install it on a computer. That being said, it sounds like the stick itself is bad. It won't work on any computer so that rules out a computer issue. Since you cannot access it once it recognizes the drive, the media has become corrupted or gone bad. Try right clicking on the drive and formatting it but if that doesn't work, I'm afraid its toast.
Jul 02, 2007 | AOpen AX4B Pro-533 (91.88M10.102)...
Intenso 6002510 Memory Station 320Gb Usb 2.0 2.5 Inch External Hard Drive Black Logo
65 people viewed this question
Top Intenso Computers & Internet Experts
David Payne
David Payne
Are you an Intenso Computer and Internet Expert? Answer questions, earn points and help others
