Question about Lionel 711020 Harry Potter Hogwarts Express Set
Traction tire, part no 710-1020-206 is unavailable
Is there an alternative that can be used ?
    New Friend:
  • 161 Answers
You can try the product called Bullfrog Snot.
It can be applied in even layers until the desired thickness is achieved.
Alternetly, you might try an appropriate sized rubber O ring from your local hardware store.
Posted on Oct 09, 2014
PT Cruiser 2001, The tracking system is coming engaged when I slow down and causes the car to shake. Can I disable the tracking somehow?
If your car has traction control from the factory, then you should have an easily visible switch located under your radio which is used to temporarily disengage the system. Push it in for a moment until the light on your dash (by the fuel gauge) comes on. Alternatively, I would explore the possibilty that one of your tires has separated from its tread and that is the actual cause of the shaking. This is easy to check the next time you or your shop rotates the tires, just look for out-of-round tires or bulges on the tires. A bad tire should be covered at least partly under its manufacturer warranty.
Mar 07, 2015 | 2001 Chrysler PT Cruiser
Warning lights stay lit-
this dealer is a joke abs maybe faulty sensor traction control try check the fuse on the fuse box if is blow replace if nothing happens needs a computer diagnostic
Dec 30, 2013 | 2008 Lincoln MKX
On a 2002 Saturn vue does having the traction control off make a difference in tire wear ?
The only way it will make a difference in tire wear is if you are constantly spinning the tires and wearing them prematurely. If you are just turning traction control off but not spinning the tires any more than before you will not have any more wear.
Jun 11, 2012 | Cars & Trucks
What is traction control sistem
TRACTION CONTROL: An enhancement of an existing ABS system that prevents wheel spin while accelerating on wet or slick surfaces. It uses the same wheel speed sensors to monitor wheel speed during acceleration, but requires some additional control solenoids and a pump to apply braking pressure to control wheel spin. The traction control system brakes the drive wheel that's starting to spin to shift torque to the opposite drive wheel that still has traction. Most traction control systems only operate at speeds up to about 30 mph. Additional control strategies that some traction control systems use to limit wheel spin include reducing the throttle opening, upshifting the transmission, retarding spark timing and deactivating fuel injectors.
Hope helps.
Dec 23, 2010 | 1996 Acura RL
No traction. Is there somthing you can put on the tires.
yes there are traction bands or some have used bmx tires screwed to the tires. these will help but so shorten the life of the gears, so i dont recomend it, but no traction is very frustrating.
good luck!
Dec 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
I cannot find any traction device for my Buick Lucerne.
yes try tire cables there smaller in clearance than chains and as effective. they may be slightly more price wise but this should get you by. happy travels.
Dec 29, 2009 | 2009 Buick Lucerne
My 1998 BMW traction control warning light is coming on regularly
Yes definitely check the tread on your tires, they are slipping around corners that's why the traction control comes on. It could like you said be low tire pressure but they would have to be pretty low and you would notice if they were that low. The traction control is sensitive in the bmw's that's what makes them great.
May 19, 2009 | 1997 BMW 328
Service traction system light on after getting new tire
wheel bearing about to go bad.. Notice any slight roaring noise??
Mar 17, 2009 | 2003 Oldsmobile Silhouette
I just need to understand what traction control means. Do I need specific tires for specific conditions? I live in Minnesota and the tires seem to have no traction....although I am supposed to have...
traction control helps you keep better traction on wet roads and helps you maintain control of the car. no you dont have to have certain tires on the car for the traction control to work. it helps you drive better on wet roads and on snow etc.its built into alot of vehichles these days .
Dec 16, 2008 | 1992 Lexus Ls 400
Lionel 711020 Harry Potter Hogwarts Express Set Logo
106 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
