Marantz sr6200 connect via optical cable no sound
    Guru:
  • 417 Answers
Need more input.........
connected what ?
i'll give you a tip about optical sound.
if the socket glows red it's an output, if it doesn't then its an input.....optical sockets don't work two way, like some people seem to think.
other then that try selecting the optical channel using the source button.
Posted on Mar 19, 2014
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
SOURCE: NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: Marantz 6200
Your unit's micro IC, is in need of a reset.Un-plug the unit and locate the semi large yellow capactor on the main board. (r-h side facing front) Now flip the unit over and look thru the vent holes in that same area and locate the two solder pins. Short them out with a thin metal object, like a straightened out paper clip or wire, and turn it over (just discharge the cap and remove your wire) this will default all settings and restore normal operation.
Posted on May 27, 2009
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
Jan 01, 2015 | Marantz Audio Players & Recorders
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
Oct 20, 2013 | Marantz SR-6200 Receiver
No image, only sound when connecting marantz sr 7005 hdmi out to hdmi in on tv philips 47pfl9632d
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Jun 14, 2011 | Marantz SR7005 Receiver
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
If I purchase a sr6200 with out the remote will I be able to operate it properly?
Since the inception of AVR's and the need for user setup from a listening position the remote and a basic TV video connection are indispensable.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR6200-Receivers-manual/id/511dj786/t/2/
Given the aftermarket price of remotes, I can see why you ask.
http://remotes.com/remotes/servlet/rs?&smodel=C350&brand_pn=NAD_C350&o=c&o=c&a=Search&uid=0&m=sr6200&uuid=A13018400293721
Apr 03, 2011 | Marantz SR-6200 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
Cannot get jamo 250 subwoofer to work via marantz SR4002. Have power but no sound. Also are trying to connect PS3 via HDMI which is no probs however, cannot connect via optical audio
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Nov 02, 2009 | Marantz SR4002
Marantz sr7200
Most likley, if I'm right, you have heard some staitcy, crackly noises, accompanied with this failure. If so, the problem is without a doubt on the D.S.P. board, witch is the one with the optical jacks on it, The culprits would then be I.C. 719 & I.C. 720. This is a common problem with this model, and the sr6200 & 5200 as well. A low tech method to confirm this is to touch IC 720 (the smaller one) while it's on. If you can keep your fingertip on it for at least ten seconds, it's ok, and the problem is elsewhere. If not, (IT WILL BE VERY HOT) the the board must be removed (27 screws from left to right) and replace BOTH IC719 & IC720.
Dec 25, 2008 | Marantz SR-5000
Playstation 3
I assume that the Marantz has an Optical lead input. If so you should connect an digital optical lead directly between the PS3 and the Marantz receiver for the sound while keeping the HDMI lead to the projector for the picture. You will need to configure the PS3 to be outputting the sound to the optical output (done through the settings menu).
Jan 08, 2008 | Marantz SR-5200 Receiver
105 people viewed this question
 Grubhead
Grubhead
