Wont switch on philips /42pf9831d/10 - Televison & Video
Philips 26pf5321/10 wont tune in
check in sam(062596+info button) or sdm(062596+menu button) menu if you have changed anything by mistake!Consult the service manual about the blinks that the tv shows you!!
Nov 10, 2012 | Philips Televison & Video
Dvd plays for 5 mins maybe 10 then stops playing switches itself off wont power up again for a few mins even do the red light comes on
This is a fault with the TOP249 switched mode power supply controller. I had the same problem and freezer spray on this chip on the power supply card started it workig quickly. Ageing of the chip has reduced the temperature sensing at which thermal shutdown cuts in. Bought a new chip off ebay for £4. Took out old one and fitted new one. Problem solved.
Apr 03, 2012 | Philips LX3700D System
Philips 42pf9831d/37 tv. the power goes out, red LED flashes once then four times then repeats. I've opened the back and see no bulging caps. Any ideas?.
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=Philips&megnev2=42pf9831d&kategoria=&kat2=all
The standby power supply is working but the rest of the power supply may not be working or it is in shutdown due to shorted circuits.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 28, 2011 | Televison & Video
TV turns on by itself
As far as I know this has been a rare incident. It could be an electronic switch. The TV's on button (if I am not mistaken) is like a sensor that detects touch. That may have turned faulty or there are bad connections internally that send signals to the circuit similar to a person actually turning on the TV. Just to isolate the problem see if you can remove the battery of the remote. The problem may be with the remote. As for the blue glow, if it is on the screen inspect the board for leaking capacitors, blown fuse or loose parts internally. It could be caused by voltage fluctuating internally or just parts not working as it should be. This may be related to the TV turning on by itself and replacing or correcting the bad internal parts you may solve the first problem.
Oct 09, 2009 | Philips Televison & Video
Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Sep 11, 2009 | Televison & Video
My Philips 19pfl3403d/f7 wont turn on without unplugging first.
just call philips and they will send you a new t.v.! it isn't a recall, that would be bad publicity!! i spoke with a philips representative yesterday concerning my 'possessed' television. a gentlemen informed me that philips has a 'rapid replacement program' for the described 'possessed' t.v. set. simply provide model and serial numbers, time and place of purchase, then provide street address for fed-ex delivery. approximate time of arrival is 10-15 days. you are directed to package and return the old set to nearest fed-ex pick up site. i am super excited that i took the time to call philips support. i think that i spent a total of 10 minutes on the telephone; it was time well spent. oh yea, here's the number!
Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Mar 31, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
