Question about Dataproducts Office Equipment & Supplies
Dataproduct print funny character - Dataproducts Office Equipment & Supplies
My LB 615 is printing just the top part of each character - I have a hunch one of my 'new people' may have accidentally changed a setting on the FLT or other keypad keys. Any suggestions?
The FLT setting would affect character spacing left to right by setting the distance the hammer has to move to get to the platen.
Phasing affects character formation by adjusting the timing of the hammer.
If your characters are missing the tops of all of the characters your band has been moved from the correct tracking on the band pulleys.
Adjsutment is made with the blue lever on the right Idler Pulley, Flip the lever down to release tension and slide the band back to the pulley flanges. LIft the lever and spin the pulleys counterclockwise a few rotations. Make sure the band doesn't "walk" out again as that would indicate a problem you would need tools to fix.
Also make sure the ribbon is tracking properly as that can cause poor character formation.
Dec 21, 2010 | Dataproducts LB-615 Printer
Printing funny characters
You may want to use a new driver from www.star.com when you are printing make sure your using the right driver.
Sep 21, 2010 | Matrix Star SP200 Receipt Printer
TYPING EVERY CHARACTER BUT WHAT I'M ACTAULLY TYPING-
Check for KBII and PS (ketboard II , Proportional space) or any bthing interfearing with the printwheel.
DickyO
Apr 06, 2010 | Brother SX-4000 Typewriter
BP 2000 priner has minor steps in print line. The characters are not always even on a horizontal line.. some of the characters are light like the dollar sign. It has a new band but the robbbon ink builds...
This is usually due to the tractors not being set right.
There is a FINE LINE of having enough tension and tearing out the tractor strips.
ANOTHER problem is static electricity charges that create random drag on the paper either from the paper source or the output hopper.
In these cases, increase the humidity to 40% or use an ionizer in teh vicinity.
Nov 10, 2009 | Dataproducts FP 2000A Matrix Printer
When we start to print a message apper that reads
Clean your Carriage Roller and Replace Carriage Felt
Nov 05, 2009 | Dataproducts 8524 Matrix Printer
Gosting problem
Take off the ribbon and wipe and clean the area around the printhead, you probably have buildup there. Check the ribbon and make sure that it is in good shape and not fraying.
If you cannot get to the face of the printhead, you can remove it to make cleaning easier
Jun 22, 2009 | Dataproducts FP 2000A Matrix Printer
Getting different character printout after replacing Timing and s
hello sir; there are so many difference sub-manufacture around the world, they made their ovwn language, so you have to reset, just press the manu key search for language,pick up english should be ok!
Dec 30, 2008 | Dataproducts FP 2000A Matrix Printer
Driver Dataproducts printer 8524
8524 Series
This printer supports the follwing emulation modes:
  • IBM 2391
  • Epson LQ-2550
  • HP 480 RuggedWriter (PCL3)
RPSA does not provide drivers for this printer. They are found on the Windows installation disks.
Jun 21, 2008 | Dataproducts 8524 Matrix Printer
15 people viewed this question
Top Dataproducts Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dataproducts Office Equipment and Supply Expert? Answer questions, earn points and help others
