Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Metalic noise when drum rotates
I hear a metalic screaching noise when drum of my top load CANDY CT 745 T rotates. I suppose there is something metalic between drum and its case. How can I reach there?
George
    Problem Solver:
  • 9 Answers
Something has got in the tub or the bearing is going bad.
If something metalic has gone through a hole or over the top rim, you want to get it out immediately because further use will cut a hole in the tub or damage the drum.
If it's the bearing, it would likely have started soft & gotten louder with time. Is there any play in the drum if you try & move it side to side?
Posted on Jul 02, 2009
I have a candy condenser gcc58onb it is making a terrible noise when it turns the drum turn s what is this?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Feb 21, 2015 | Candy Dryers
It is an Automatic washer. When spinning/rinsing, there is a noise of metal screaching and the drum is of balance. The load is not ofbalace. How do I rectify this problem?
check it is sitting on floor level, it is easier to use a spirit level to check this or alternatively get a peice of square plywood cut to the same as machines outer diameter and place it under the appliance
Mar 12, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Why is my dryer is making a high pitch screaching noise?
frigidaire dryers have a rear bearing that the drum rides on,usually when you hear metal on metal sounds it will be the rear bearing
Feb 22, 2012 | Frigidaire FER641FS Electric Dryer
My dryer is making loud screaching noises. Everytime I turn it on to dry clothes is makes very loud screaching noises.
Sounds like it needs what are called glides or felt. This is what keeps the metal drum from contacting the metal housing. If this is let go too long the drum can be ruined
Dec 01, 2009 | Dryers
My Candy automatic washing machine will not spin
Try the drive belt from motor to the drum it could have stretched a little? The noise you can hear could be the heating element catching the inner drum or something like a wire from a bra came loose in a wash and is trapped between the drums ?
Nov 05, 2017 | Candy Washing Machines
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
Drum fails to operate at times and making a screaching noise. Sometimes drum needs to be spun by hand to get it operating and spinning.
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Sep 13, 2009 | Dryers
Off balance, loose drum?
If your machine produces a lot of banging noises when in a permanent press final spin you may be experiencing a broken spider. It is a part which is not made from stainless steel metal, but attached to a stainless still drum (tub spin). So, when it is soaked in water all the time during a normal operation of a washer it creates a galvanic element between a stainless still drum and itself. This results in severe corrosion of the "spider" and then leads to it's breakage. To check if you have a broken "spider" open the door of the washer and try to kick your internal drum back and forward while rotating it slowly.If you will hear clicking noises (metal to metal) in some position of the drum it means that your spider is broken. The replacement of this spider will require complete disassemble of the drum. Most likely you will end up replacing this whole part
Drum assembly, spin basket Part # 131618500Another way is get just a spider part, it's doable, but may be tricky.
Cheers!
Oct 29, 2008 | Kenmore 44042 Front Load Washer
BOSCH V651 Front Loader
suspect you have a foreign object jammed between tub and drum.
to check, remove back panel, remove heater (held by one 10mm nut in the centre - just loosen the nut and prise the heater out.
you can then see into the gap and check if there is something stuck there - bra wires are the favourite
Oct 02, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
201 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
