Question about Canon Service Manual For Ir 400
First tray paper not dedected in canon ir 400 zerox machine
Cogz
  • 1326 Answers
SOURCE: canon ir 400 photocopier
What is the sub error code E805-" " -007 is is a blown fan and a blown fuse on the DC control. " " -002 could be a broken connection or pinched wire under the adf pillar on the right rear near the fixxing unit. If your have more info. on the code let us known..... Good luck
Posted on Apr 14, 2008
  • 39 Answers
SOURCE: CANON IR 400 WEB ROLLER HOW IT IS FIXING.I WANT VIDEO FILE
That is a little question with a big answer. You first need to buy a web ($10-$30) and then replace the old one with it. This requires tools and if that appeals to you then I'll write the rest of this response, but it's a dirty job. The only tool you really need is a Phillips #2 screw driver. Else if this doesn't appeal to you then call a copier tech to do the job. Good luck either way.
Posted on Dec 17, 2009
Testimonial: "how to fixing the ir 400 web roller "
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
How to remove canon ir 400 paper feeder assembly
Why???? The unit comes out the right side of the copier. There are alot of screw to be removed. You can take the paper trays out and remove a paper jam and also replace the rollers. If the paper tray is not lifting? There is a lift gear that breaks and it is not easy to replace> I have over 20 years and it is not easy to do......
Jul 28, 2010 | Canon imageRUNNER 400S Copier
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Canon ir-400 error load paper when i give data print
More than likely your computer's setup for where it is to pull the paper from has designated the manual bypass tray (the flap on the side of the right side of the copier that holds paper) as it's main source. Go into the control panel/printersandfaxes/ and look under the profile tab of your copier. Good luck
Dec 09, 2009 | Canon Office Equipment & Supplies
Canon ir 400
Switch off machine
Open the rear cover then you see the green board
right hand up side it calls dc board remove all connection
re insert them.
switch on copier.
If problem exist replace the board.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Canon Service Manual For Ir 400 Logo
35 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
