Question about Ardfry Imaging PSD Codec
Ardfry psd codec name and serial number - Ardfry Imaging PSD Codec
How to resolve the problem with psd file?
There are many reasons that cause this error. you can prefer to use good PSD file repair software. PSD Open File Tool - is the best option to fix all Photoshop file errors
Here the link: https://www.openfiletool.com/psdopen.html
Sep 27, 2016 | Computers & Internet
I need a n264 codec to play cctv footage
You have to uninstall other codec packs.
Try the K-Lite Mega Codec pack.
Maybe it is H264? THe VLC player or the Media Player Classic can play those videos on their own.
Nov 08, 2013 | Computers & Internet
No audio output is installed
If you haven't already done this, try going to the man Manufacture's web page, get into the drivers & downloads area to download the driver that should be with or installed your Laptop when first purchased. Sometimes the manufacture will not only have the driver download of the original that suppose to be there, but also have an updated one to download. Make sure you have the proper name, model number, serial number and or sid number on hand so you can get the right driver.
Check you device manager also to see what version may have been there or may still be there. Sometime the device manager will have a link for an updated version (try using the link first).
You may need to download an audio codec to fix the problem too. That too is a driver download that should be listed on the manufacture's web site. If you can't locate the driver's you need on the manufacture's web site you can google "free codec""free audio driver download for ? (name of manufacture) laptop."
I hope this will help you, I'm guessing here, without more knowledge of your problem. This problem you seem to have sounds like the one that others have experienced after receiving an update from some place (like Microsoft). good luck
Jul 14, 2011 | Computers & Internet
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
Mar 28, 2009 | IBM Computers & Internet
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Videos on HTC HD not playing smooth
Try coreplayer. It plays most media without issue - its $29 though. The serial number they provide is tied in with the owner/device name so cracked versions with a serial number must also have a owner name supplied or it won't work.
This software has fixed my playback issues.
Mar 15, 2009 | HTC Touch HD Smartphone
Psd to jpg
You probably need to flatten the image to get it into a background layer only. Choose in menu: Layer/Flatten image then try to save your image.
If it didn't work, then most likely your image is in 16 bits/channel mode, change it to 8 bits/channel. Choose in menu: Image/Mode/8 bits/channel.
Dec 19, 2008 | Adobe Computers & Internet
Computers & Internet Logo
67 people viewed this question
Top Ardfry Imaging Computers & Internet Experts
David Payne
David Payne
Are you an Ardfry Imaging Computer and Internet Expert? Answer questions, earn points and help others
