Question about Canon imagePROGRAF W7200 InkJet Printer
Error E02508. Canon W7200 NO M ink
3 Suggested Answers
SOURCE: Problem in w7200
Hi - I had a different problem involving the carriage, but the solution may help you. There is (or should be) a pin on the carriage, visible on the right side when you lift the plastic pieces that hold in the printhead. This pin is about 2 in long and varies in diameter from about 1/8 inch diameter to 3/16 inch diameter. If this pin is not there, which in my case it had fallen down into the ink purge unit, the black will be shadowed by magenta. I don't know how to fix that part, but if the pin is gone you may soon have a bigger problem, which is the pin binds in the gears of the ink purge system and the printer won't do anything after that. Check for the pin, and if its gone and you live in an area where someone can service your machine call them up! In my case i was able to dig the pin out myself and the printer works again, but there is a slight overshadow of magenta.
Posted on Nov 28, 2007
SOURCE: Canon W7200 Error code E02D05
E02D05
Air flow fan error Airflow is not detected
1.Cable connection check
Replace the cable between the air flow fan and engine controller if the connection is
not functioning normally.
2.Replace the air flow fan.
3.Replace the engine controller.
4.Replace the system controller
Cheers Edwin
Posted on May 14, 2009
Canon w7200
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 16, 2013 | Canon imagePROGRAF W7200 InkJet Printer
Canon w7200 service manual
You can download service manual for CANON W7200/W7250 from;
http://dl.owneriq.net/f/fb283499-7d17-4044-bf68-b415e6ed0073.pdf
Regards;
Hassan
Sep 03, 2009 | Canon imagePROGRAF W7200 InkJet Printer
W7200
Take it out and clean all contacts, worth a try as they cost £500 from canon. An engineer told me they usually only last about a year and after problems with the cutter failing and colour problems in drawings we got a new one which fixed the problems. Third new printhead in 4 years, canon should be ashamed.
Oct 07, 2008 | Canon imagePROGRAF W7200 InkJet Printer
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Problem in w7200
Nov 21, 2007 | Canon imagePROGRAF W7200 InkJet Printer
Canon imagePROGRAF W7200 InkJet Printer Logo
43 people viewed this question
old marine
old marine
