Question about IBM SAS Backplane For System x3850 x3950 (All Models) 41Y3161 Hard Drive
File system read only
Fyle system keeps going into read only mode but Hard disk is ok
  • 151 Answers
Sounds like an issue with ownership change.
Posted on Apr 02, 2014
When I look in disk manager it shows my external hard drive is in raw
DO NOT FORMAT YOUR DISK. It has been damaged; how easy or even possible to recover your data depends on the degree of damage.
Try your HD in another computer; if it works, make a back-up of your files on another disk.
To understand what RAW format means, try this
http://www.ehow.com/facts_7167186_raw-disk-format_.html
or look for it in Wikipedia.
By searching the internet ("raw disk has data on it"), the first article I found was this
http://html5.litten.com/how-to-fix-external-disk-drive-suddenly-became-raw/
which may be of some help.
In that article a Linux system is used to read and modify the disk. There other tools for repairing this type of fault, for example, http://www.easeus.com/resource/recover-raw-disk.htm
(I do not know if this free:: the information in the article is certainly free though)
Recovering your files will probably mean a lot reading, research and time, but you might be lucky. I recommend reading any article you are going to use through to the end before you start with it.
25.April.2014
Mar 03, 2014 | Computers & Internet
Error every time i attempt to copy a file of more than 6gb to the drive.
It's normal if the drive is hormatted in FAT32. If you want to use files bigger than 4.5gb you need to format it in NTFS. you can do it by right click the hard drive in "Computer", select "format", then select the Fyle System in NTFS.
BE CAREFUL: doing this will erase EVERYTHING you have on your hard drive.
Mar 01, 2011 | Western Digital Passport 320GB External...
My operating system is corrupted by a virus i tried to slave my hard drive but i can only see my hard drive in bios and i cannot see it in my local disk drive and im hearing clicking sound inside my hard...
Try to boot from your OS cd or recovery disc. Run the disk check software and see if your hard disk is mechanically ok or it crashed. If your hard disk is mechanically functional then run virus check on your hard disk. This will clean all the virus infections. And you will be alright hopefully.
If your hard disk's boot sector is damaged you may want to format the hard disk and place the boot sector in another portion of hard drive.
Nov 07, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
HARD DISK reading but no files appearing..!!!
Sometimes this happens when the computer is turned off by force e.g. lightning/suspend mode. You'll have to use hard drive recovery tools in my oppinion which could cost quite a lot.
Dec 22, 2009 | Computers & Internet
How to configure bios to read sata hard disk
To configure your bios to read sata hard disk follow this Steps:
1. Power on the computer
2. Keep pressing the delete keys until bios utility will show
3. Go to the advance settings
4. Find the Sata Mode and then change it to IDE:
5. Save changes and Exit
Hope this could help.
Sep 27, 2009 | MSI K8MM-V Motherboard
MY COMPUTER KEEPS READING THE ntldr FILE IS MISSING,,HOW DO I FIX THIS
ntldr is required to boot. It sounds like your file system may be destroyed - this is rather serious!
If you have important files on the hard disk then buy another hard disk and re-install the Operating System onto the new hard disk (remove the old one).
When it is working, add the old hard disk and see if you can read it. If you have IDE hard disks you must set them both to Cable Select (CS) if they are on the same cable (or set one to Master MA and one to SLAVE SL).
If you don't have anything too valuable on the hard disk, then boot to your Recover CD that came with the system and see if there is a repair option.
Or take it into a local PC rrepair shop fi you are unsure about any of the above!
Aug 03, 2008 | Gateway Computers & Internet
Disk data is in read only mode. How change to Read/Write?
If you are referring to files on a CD, they are read only because a CD does not allow you to write on it after it has been created.
You need to copy the file from the CD to your hard drive, edit, and resave it there.
If the file is already on your hard drive and is read only, you can right click on the file name, and select Properties. Clear the "Read Only" check box and choose OK.
Jul 15, 2008 | Microsoft Word 2003 for Students &...
Booting issue
You have a hardware failure of the hard disk drive. Only way to resolve is to replace the hard drive that is failed.
Apr 28, 2008 | HP Compaq dc5700 Microtower - Free Flat...
IBM SAS Backplane For System x3850 x3950 (All Models) 41Y3161 Hard Drive Logo
26 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
