Question about Pioneer AVH-X5500BHS
Avh-x5600bhs screen stays at 45 degree angle
After only 10 minutes of operation. I tried to set the screen angle. at first it worked as manual said. I tried to return it to the fully closed original position. After about 3 tries it went to 45 degrees. No matter what i do it returns to that position and will not adjust
2 Suggested Answers
  • 1894 Answers
SOURCE: AVIC - Z1 Screen no longer retracts to allow insertion of a CD
that means that the CD drive is not opening right?
it may be a gear problem sir
Posted on Jul 30, 2008
Do you know where i can source a manual for a Ryobi 1800w 254mm Compound Sliding Mitre Saw model EMS 1825 SCL
normally they do
they cut at angles across the material
there is also a adjustment at the back of the slide that allows the head to be tilted
there is an angle gauge there and a pointer to give you the tilt angle
by adjusting that and the across the bed angle , you can cut compound angles
set the angle and then test cut as the angle may not always be exact ( setting it on 10 degrees on the scale may be 10 1/2
degrees in reality so testing gets it dead right)
adjust as necessary
Oct 12, 2016 | Saws
For a 10ft radius octagon, how long should each side be?
There is probably a formula for this or other ways of doing this, but I will give it a shot.
An octagon has 8 sides (octopus has 8 legs). To make an octagon, we effectively have 8 triangles joined at the centre. In the centre, we have 8 equal angles. Since a full circle is 360 degrees, each of these angles must be 360 / 8 or 45 degrees.
Now we can just focus on one of these triangles. We have an angle of 45 degrees at the centre and two arms extending out 10 feet.
At this point, we can use the cosine law to calculate the length of the side or we can recognize that it is an isosceles triangle and work out the other angles and determine the length of the side.
Using Cosine Law, a^2= b^2 + c^2 - 2xbxc Cos A
In this case, A = 45 degrees, b = 10 feet, c=10 feet.
Good luck.
Let me know if you have any questions.
Paul
Aug 25, 2015 | Miscellaneous
My Pioneer AVH-X5600BHS resets everytime I turn off my car, how can I stop this?
probably was not installed correctly.needs to be wired correctly or has a bad fuse
Mar 24, 2014 | Pioneer AVH-X5600BHS DVD Receiver
Angles degrees plus enter
In Run>Mat or in PRGM press the OPTN key. Pan to the next page by pressing F6>. the F5:ANGL
To enter a number in DMS use the F4: [deg '"]
Example :type in 15 deg 45 minutes 10 seconds
15 [F4] 45 [F4] 10[F4] then enter. The result is displayed in Decimal Degrees as 15.7277778
Press F5 [deg '"<==]
The number is converted to DMS.
See the screen capture.
Dec 27, 2013 | Casio Algebra FX 2.0 Calculator
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
What is the reference angle of 225 degrees and 15'
The answer to this is 45 degrees and 15' i.e. forty five degrees and 15 minutes. Each degree is split into 60 minutes. So that 15' would be 15/60 degrees. that means 225 degrees and 15' is equal to 225.25 degrees. The reference angle is given by = 225.25 - 180 degrees which is equal to 45.25 degrees. This is in fact 45 degrees and 15'.
Please vote for the answer!
Jun 28, 2011 | Computers & Internet
Doesn't stay flush to bottom, good suction, if I hold front portion down it works great!
It's most likely a piece of debris in your flapper of your automatic pool cleaner. Debris may prevent flapper movement or restrict flow. You might also want to check for proper hose balance. The hose should stay at a 45 degree angle to the pool floor. If it is greater than a fourty five degree angle, the hose is too light. Move the weights closer to cleaner, or move the first two weights closer to each other. If it is less than a 45 degree angle, move the weights away from cleaner, or separate the first
two weights away from each other.
Feb 12, 2011 | Universal Kreepy Krauly In-Ground Pool...
How can I find sin 45degrees 20 minutes using a fx-9750G PLUS calculator?
The problem is not finding the sine of the angle but expressing the angle in Degree Minutes Seconds instead of decimal degrees.
  1. In RUN screen press [SIN] function key
  2. Press [OPTN]
  3. Press [F6] to get to next page of menus.
  4. Press [F5:Angl]
  5. Enter 45 and press [F4: degree ' "]
  6. Enter 20 and press [F4: degree ' "]
  7. If you have seconds to enter, type in value and press [F4:degree ' "]
  8. Press [EXE] to get your result.
This procedure will give you the sine regardless of the angle unit the calculator is configured for.
Sep 30, 2010 | Casio FX-9750GPlus Calculator
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Pioneer AVH-X5500BHS Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
